Samsung Radiant360 R3 Motherboard Replacement
  1. Samsung Radiant360 R3 Motherboard Replacement, Wireless Setup Button and USB Module: step 1, image 1 of 3 Samsung Radiant360 R3 Motherboard Replacement, Wireless Setup Button and USB Module: step 1, image 2 of 3 Samsung Radiant360 R3 Motherboard Replacement, Wireless Setup Button and USB Module: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
    Ask FixBot
  2. Samsung Radiant360 R3 Motherboard Replacement: step 2, image 1 of 1
    • Remove the bottom shell from the speaker.
    Ask FixBot
  3. Samsung Radiant360 R3 Motherboard Replacement: step 3, image 1 of 2 Samsung Radiant360 R3 Motherboard Replacement: step 3, image 2 of 2
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
    Ask FixBot
  4. Samsung Radiant360 R3 Motherboard Replacement: step 4, image 1 of 1
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
    Ask FixBot
  5. Samsung Radiant360 R3 Motherboard Replacement: step 5, image 1 of 1
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
    Ask FixBot
  6. Samsung Radiant360 R3 Motherboard Replacement, Wireless Module: step 6, image 1 of 2 Samsung Radiant360 R3 Motherboard Replacement, Wireless Module: step 6, image 2 of 2
    • Remove the two 12mm long screws with the Phillips #1 screwdriver.
    • Unplug white plug connected to the green circuit board.
    Ask FixBot
  7. Samsung Radiant360 R3 Motherboard Replacement: step 7, image 1 of 2 Samsung Radiant360 R3 Motherboard Replacement: step 7, image 2 of 2
    • Remove the four 12mm long screws with the Phillips #1 screwdriver.
    • Remove the cover, and slide the cord through the hole.
    Ask FixBot
  8. Samsung Radiant360 R3 Motherboard Replacement: step 8, image 1 of 3 Samsung Radiant360 R3 Motherboard Replacement: step 8, image 2 of 3 Samsung Radiant360 R3 Motherboard Replacement: step 8, image 3 of 3
    Buy
    • Remove rubber covers covering the screws with pair of tweezers.
    • Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver.
    Ask FixBot
  9. Samsung Radiant360 R3 Motherboard Replacement: step 9, image 1 of 1
    • Remove the unscrewed cover as much as possible.
    • It is very difficult to get plugs at the end of the cord through the cover without breaking, so just slide to the edge.
    Ask FixBot
  10. Samsung Radiant360 R3 Motherboard Replacement: step 10, image 1 of 3 Samsung Radiant360 R3 Motherboard Replacement: step 10, image 2 of 3 Samsung Radiant360 R3 Motherboard Replacement: step 10, image 3 of 3
    • Push the body out through the outer shell of device.
    • Carefully push the ring attached to the cable through the shell.
    Ask FixBot
  11. Samsung Radiant360 R3 Motherboard Replacement: step 11, image 1 of 3 Samsung Radiant360 R3 Motherboard Replacement: step 11, image 2 of 3 Samsung Radiant360 R3 Motherboard Replacement: step 11, image 3 of 3
    • Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver.
    Ask FixBot
  12. Samsung Radiant360 R3 Motherboard Replacement: step 12, image 1 of 2 Samsung Radiant360 R3 Motherboard Replacement: step 12, image 2 of 2
    • Pry the two halves of the body open using a metal spudger.
    Ask FixBot
  13. Samsung Radiant360 R3 Motherboard Replacement: step 13, image 1 of 3 Samsung Radiant360 R3 Motherboard Replacement: step 13, image 2 of 3 Samsung Radiant360 R3 Motherboard Replacement: step 13, image 3 of 3
    • Remove the plugs located topmost right and closest to the bottom in picture.
    Ask FixBot
  14. Samsung Radiant360 R3 Motherboard Replacement: step 14, image 1 of 1
    • Remove the four 12mm long screws with the Phillips #1 screwdriver .
    Ask FixBot
  15. Samsung Radiant360 R3 Motherboard Replacement: step 15, image 1 of 1
    • Unscrew the four 8mm screws on the side of the motherboard with the Phillips #1 screwdriver .
    • Remove the Wireless Module from the device.
    Ask FixBot
  16. Samsung Radiant360 R3 Motherboard Replacement, Subwoofer: step 16, image 1 of 2 Samsung Radiant360 R3 Motherboard Replacement, Subwoofer: step 16, image 2 of 2
    • Disconnect the plug in the device.
    Ask FixBot
  17. Samsung Radiant360 R3 Motherboard Replacement: step 17, image 1 of 1
    • Slide the subwoofer out of the speaker.
    Ask FixBot
  18. Samsung Radiant360 R3 Motherboard Replacement, Motherboard: step 18, image 1 of 2 Samsung Radiant360 R3 Motherboard Replacement, Motherboard: step 18, image 2 of 2
    • Disconnect the six plugs on the motherboard.
    Ask FixBot
  19. Samsung Radiant360 R3 Motherboard Replacement: step 19, image 1 of 1
    • Remove the ZIF cable.
    • Pull up the tab with a spudger, and life the cable.
    Ask FixBot
  20. Samsung Radiant360 R3 Motherboard Replacement: step 20, image 1 of 2 Samsung Radiant360 R3 Motherboard Replacement: step 20, image 2 of 2
    • Remove the four 12mm screws with the Phillips #1 screwdriver .
    • Remove the motherboard from the device.
    Ask FixBot
Fadi Alzammar
782 Reputation
5 Guides authored
Cal Poly, Team S25-G18, Maness Spring 2018 Member of Cal Poly, Team S25-G18, Maness Spring 2018
CPSU-MANESS-S18S25G18
4 Members
5 Guides authored
1 Guide Comment
What kind of DAC is in the motherboard?
Gera Mare - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 694
