Up to 20% off select tools
Samsung Radiant 360 R1 Bluetooth Module Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
110
All Time:
1,780
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
There could be many reasons the Bluetooth module on the device will not connect, such as water damage or electric shock. This guide will show you step by step how to replace a non-functioning Bluetooth Module. In order to start working on your device, you will need to prepare a clean, dry, and flat work space. It is recommended to have a place to store screws during the process.
    1. Samsung Radiant 360 R1 Bluetooth Module Replacement, Micro USB / Power Port Panel: step 1, image 1 of 1
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
      • Use the plastic opening tool to lift and remove the rubber grommet plugs.
      Ask FixBot
    2. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 2, image 1 of 1
      • Using a PH1 Philips screwdriver, remove four (9.5mm x 1.6mm) screws from the base plate.
      • Remove base plate by stabilizing speaker and using plastic prying tool to pry the base plate from the speaker.
      Ask FixBot
    3. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 3, image 1 of 1
      • Place the speaker on the table with the Touch Pad facing down. This will leave you with the Port Panel exposed.
      • Remove speaker grill by stabilizing speaker on a table and applying pressure to the bottom of the speaker. Slide the speaker grill up and away from the remaining endcap.
      Ask FixBot
    4. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 4, image 1 of 1
      • Remove the two exposed (9.5mm x 1.6mm) PH1 Phillips screws on the Port Panel.
      • Remove the Port Panel from the speaker body, exposing the ribbon cables.
      Ask FixBot
    5. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 5, image 1 of 1
      • While stabilizing the Port Panel remove the two ribbon cables one at a time by pressing the locking clip down on the ribbon cable connectors and pulling the connector away from the Port Panel.
      Ask FixBot
    1. Samsung Radiant 360 R1 Bluetooth Module Replacement, 1" Tweeter Speaker: step 6, image 1 of 3 Samsung Radiant 360 R1 Bluetooth Module Replacement, 1" Tweeter Speaker: step 6, image 2 of 3 Samsung Radiant 360 R1 Bluetooth Module Replacement, 1" Tweeter Speaker: step 6, image 3 of 3
      • Remove the four (9.5mm x 1.6mm) PH1 Phillips screws on the port speaker body.
      • Remove the Port Panel exposing the subwoofer.
      Ask FixBot
    2. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 7, image 1 of 3 Samsung Radiant 360 R1 Bluetooth Module Replacement: step 7, image 2 of 3 Samsung Radiant 360 R1 Bluetooth Module Replacement: step 7, image 3 of 3
      • Remove the eight (9.5mm x 1.6mm) PH1 Phillips screws on the right side of the speaker body.
      • Remove the one (9.5mm x 1.6mm) PH1 Phillips screw on the left side of the speaker body.
      • The body sides are denoted with a "R" and an "L" for right and left sides.
      Ask FixBot
    3. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 8, image 1 of 1
      • Open up the body to expose the inner panel and motherboard.
      Ask FixBot
    4. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 9, image 1 of 3 Samsung Radiant 360 R1 Bluetooth Module Replacement: step 9, image 2 of 3 Samsung Radiant 360 R1 Bluetooth Module Replacement: step 9, image 3 of 3
      • Remove the ribbon cable from the tweeter which is attached to the main motherboard.
      • Slide the tweeter out of the enclosure.
      Ask FixBot
    1. Samsung Radiant 360 R1 Bluetooth Module Replacement, Bluetooth Module: step 10, image 1 of 1
      • Slide rubber grommet out of slot on plastic housing.
      • This may have occurred naturally when separating the two halves.
      Ask FixBot
    2. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 11, image 1 of 3 Samsung Radiant 360 R1 Bluetooth Module Replacement: step 11, image 2 of 3 Samsung Radiant 360 R1 Bluetooth Module Replacement: step 11, image 3 of 3
      • Disconnect white connector by pushing down on the release tab while gently pulling the connector free from the socket.
      • Remove wiring harness and set aside.
      • The other connectors in the wiring harness should already be free from previous steps.
      Ask FixBot
    3. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 12, image 1 of 2 Samsung Radiant 360 R1 Bluetooth Module Replacement: step 12, image 2 of 2
      • Locate and remove the two PH2 Phillips screws from the base of the motherboard assembly.
      • These screws may be extremely tight. Be careful not to snap the plastic when removing the screws.
      Ask FixBot
    4. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 13, image 1 of 2 Samsung Radiant 360 R1 Bluetooth Module Replacement: step 13, image 2 of 2
      • Flip the motherboard assembly over and locate the Bluetooth module on the side of the metal frame.
      • Remove the one PH2 Philips screw.
      Ask FixBot
    5. Samsung Radiant 360 R1 Bluetooth Module Replacement: step 14, image 1 of 1
      • Press the white tab while gently pulling the Bluetooth module away from the connector and frame.
      Ask FixBot
Author
with
Daniel Mendoza
101 Reputation
1 Guide authored
UW Tacoma, Team 2-5, Rose Winter 2017 Member of UW Tacoma, Team 2-5, Rose Winter 2017
UWT-ROSE-W17S2G5
4 Members
48 Guides authored
4 Guide Comments
Nice write up, but where does one obtain a new Bluetooth module for one of these?
Royce Courtney - Reply Share
Where can I buy these type of bluetooth module? Ty
Payout PH - Reply Share
Bluetooth module model is WIBT30D. You can google for it. It cost ~30 euro now
Salar Mahdavi - Reply Share
You all seem to know your way around these devices. Do you think it's possible to create an 'aux' style connection to allow wired playback? If WiFi and Bluetooth are failing, having the ability to connect to connect via wire would be really good.
Fred Tuinstra - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 110
All Time: 1,780
