Samsung RS25J500DSR LED Light Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
114
All Time:
3,205
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your LED light strip on a Samsung Side By Side Refrigerator (model: RS25J500DSR) is not working, this guide will help you and lead you through your troubles. The LED light strip is an electric light for use in light fixtures. Inspect the connection connected to the LED light. Before starting, make sure to disconnect the refrigerator from the electrical outlet box. This guide provides easy and straightforward steps in changing the light on the fridge.
    1. Samsung RS25J500DSR LED Light Replacement, LED light: step 1, image 1 of 3 Samsung RS25J500DSR LED Light Replacement, LED light: step 1, image 2 of 3 Samsung RS25J500DSR LED Light Replacement, LED light: step 1, image 3 of 3
      • Disconnect the refrigerator for the electrical outlet box.
      • Remove the cover that protects the LED light.
      Ask FixBot
    2. Samsung RS25J500DSR LED Light Replacement: step 2, image 1 of 3 Samsung RS25J500DSR LED Light Replacement: step 2, image 2 of 3 Samsung RS25J500DSR LED Light Replacement: step 2, image 3 of 3
      • Disconnect the damaged light from the connection.
      Ask FixBot
    3. Samsung RS25J500DSR LED Light Replacement: step 3, image 1 of 3 Samsung RS25J500DSR LED Light Replacement: step 3, image 2 of 3 Samsung RS25J500DSR LED Light Replacement: step 3, image 3 of 3
      • Remove the damaged LED light to insert the new one on the connection.
      • Be careful not to damage the clip from the connection when removing the LED light.
      Ask FixBot
    4. Samsung RS25J500DSR LED Light Replacement: step 4, image 1 of 3 Samsung RS25J500DSR LED Light Replacement: step 4, image 2 of 3 Samsung RS25J500DSR LED Light Replacement: step 4, image 3 of 3
      • To connect the new LED light, clip it onto the connector.
      • After connecting the new LED strip reconnect the refrigerator to see if the light is working.
      Ask FixBot
Kimberlyne Barrios
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 114
All Time: 3,205
