Samsung RF4287HABP Ice Maker Repair
Views: 6.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
136
All Time:
6,634
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 1 hour
Difficulty: Easy
Introduction
Go to step 1 ↓
If the ice maker in your Samsung RF4287HABP refrigerator isn’t producing ice, you may be experiencing the common issue of over-freezing. Follow this guide to defrost and reset your ice maker.
Samsung refrigerators are well known for this problem and are currently undergoing a class-action lawsuit alleging that the ice makers are defective. This guide can be used as a temporary solution while many readers are awaiting the verdict.
Before starting this guide, inspect your icebox. A recurring concern is users are unable to easily pull out their ice maker tray and have an overgrowth of ice in the icebox. If you follow these steps and decipher the issue is not from your ice maker over-freezing, no harm will occur.
After forcing the ice maker to defrost(step 2), make sure to disconnect the refrigerator from its electrical source. All materials inside the icebox should come apart easily. Forcing materials out when ice is still present could result in damage to your ice maker.
Parts
Tools
    1. Samsung RF4287HABP Ice Maker Repair, Samsung RF4287HABP Ice Maker Repair: step 1, image 1 of 1
      • Push the “Energy Saver” button and “Fridge” button for about 8 seconds.
      Ask FixBot
    2. Samsung RF4287HABP Ice Maker Repair: step 2, image 1 of 1
      • After you hear a beep, continue to press the “Energy Saver” button until “Fd” appears.
      • The refrigerator will continue to beep for approximately 20 minutes until the ice maker has defrosted.
      • Unplug the refrigerator before beginning step 3.
      Ask FixBot
    3. Samsung RF4287HABP Ice Maker Repair: step 3, image 1 of 3 Samsung RF4287HABP Ice Maker Repair: step 3, image 2 of 3 Samsung RF4287HABP Ice Maker Repair: step 3, image 3 of 3
      • Take the ice maker tray out of the icebox and place it in the sink to melt the remaining ice off.
      Ask FixBot
    4. Samsung RF4287HABP Ice Maker Repair: step 4, image 1 of 1
      • Attempt to scrape any ice out of the icebox and defrost the remaining ice with a hairdryer or heat gun.
      • Use caution when applying heat. Excessive heat may cause the plastic to warp or melt, which could cause fit issues during installation.
      Ask FixBot
    5. Samsung RF4287HABP Ice Maker Repair: step 5, image 1 of 2 Samsung RF4287HABP Ice Maker Repair: step 5, image 2 of 2
      • Unscrew the 0.05 mm screw on the left side panel inside the icebox with a Phillips #0 screwdriver.
      Ask FixBot
    6. Samsung RF4287HABP Ice Maker Repair: step 6, image 1 of 2 Samsung RF4287HABP Ice Maker Repair: step 6, image 2 of 2
      • Carefully detach the plug connected to the thick white tube located to the left in the back of the icebox.
      Ask FixBot
    7. Samsung RF4287HABP Ice Maker Repair: step 7, image 1 of 2 Samsung RF4287HABP Ice Maker Repair: step 7, image 2 of 2
      • Press the lever down and slide the ice maker forward at the very top of the icebox.
      • If the lever is stuck, it could be from the remaining ice in your ice maker.
      Ask FixBot
    8. Samsung RF4287HABP Ice Maker Repair: step 8, image 1 of 1
      • Take out the ice tray and place it in the sink. Use a hairdryer to defrost the ice tray completely.
      • Reinsert and reconnect all the parts of the icemaker.
      Ask FixBot
    9. Samsung RF4287HABP Ice Maker Repair: step 9, image 1 of 1
      • Plug the refrigerator back into the electrical outlet.
      • Press and hold the restart button located on the top of the ice maker beside the lever.
      Ask FixBot
    10. Samsung RF4287HABP Ice Maker Repair: step 10, image 1 of 1
      • Unplug and plug the refrigerator if you do not hear a sound from the ice maker. Press and hold the restart button again until you hear water draining into the ice maker.
      Ask FixBot
2 other people completed this guide.
Madisyn
232 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 136
All Time: 6,634
