Samsung RF28R7201SG Refrigerator Control Board Replacement
    1. Samsung RF28R7201SG Refrigerator Control Board Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      Ask FixBot
    1. Samsung RF28R7201SG Refrigerator Control Board Replacement, Remove the board access panel: step 2, image 1 of 1
      • Use a Phillips screwdriver to remove the five screws securing the board access panel to the back of the refrigerator:
      • Four 14.8 mm-long screws
      • One 12.3 mm-long screw
      Ask FixBot
    2. Samsung RF28R7201SG Refrigerator Control Board Replacement: step 3, image 1 of 2 Samsung RF28R7201SG Refrigerator Control Board Replacement: step 3, image 2 of 2
      • Remove the board access panel.
      Ask FixBot
    1. Samsung RF28R7201SG Refrigerator Control Board Replacement, Reassembly information: step 4, image 1 of 2 Samsung RF28R7201SG Refrigerator Control Board Replacement, Reassembly information: step 4, image 2 of 2
      • The control board has nine wire connectors:
      • Three connectors along the top edge
      • One connector along the right edge
      • One connector along the bottom edge
      • Four connectors along the left edge
      • During reassembly, use the second image to make sure you've reconnected all nine connectors.
      Ask FixBot
    2. Samsung RF28R7201SG Refrigerator Control Board Replacement, Remove the control board: step 5, image 1 of 2 Samsung RF28R7201SG Refrigerator Control Board Replacement, Remove the control board: step 5, image 2 of 2
      • Pull and disconnect each of the nine connectors from the control board.
      • Some connectors may have a locking tab. Squeeze the wide sides of the connector to unlock it, then pull to disconnect it.
      • Move the wires away from the control board so it can slide out of its recess.
      Ask FixBot
    3. Samsung RF28R7201SG Refrigerator Control Board Replacement: step 6, image 1 of 3 Samsung RF28R7201SG Refrigerator Control Board Replacement: step 6, image 2 of 3 Samsung RF28R7201SG Refrigerator Control Board Replacement: step 6, image 3 of 3
      • Use your fingers to push up the plastic lip securing the top edge of the control board to the refrigerator.
      • Swing the control board out and remove it.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,990 Reputation
89 Guides authored
2 Guide Comments
Hola, tengo un problema con mi refrigerador samsung RF28R7201SR/AA
Ada Medina - Reply Share
No enciende el abanico , de la parte de abajo ,ya lo cambie por uno nuevo y solo enciende 5 minutos y se apaga
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 78
All Time: 777
