Up to 20% off select tools
Samsung RC512 RAM Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
82
All Time:
1,036
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
RAM replacement may need to be done when computer gets slow or RAM is damaged. Also upgrading RAM requires this guide as well. This guide will display steps to replace RAM.
    1. Samsung RC512 RAM Replacement, Battery: step 1, image 1 of 1
      • Place the laptop upside down.
      Ask FixBot
    2. Samsung RC512 RAM Replacement: step 2, image 1 of 2 Samsung RC512 RAM Replacement: step 2, image 2 of 2
      • Locate two notches above the battery.
      • Slide both battery locking notches to either side to remove the battery.
      • Pull the battery out.
      Ask FixBot
    1. Samsung RC512 RAM Replacement, Back Panel: step 3, image 1 of 3 Samsung RC512 RAM Replacement, Back Panel: step 3, image 2 of 3 Samsung RC512 RAM Replacement, Back Panel: step 3, image 3 of 3
      • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
      • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
      • Carefully remove the back panel..
      Ask FixBot
    1. Samsung RC512 RAM Replacement, RAM: step 4, image 1 of 1
      • Slide the hinges outwards to release the RAM.
      • RAM will pop up by itself. If not, lift the RAM up to about 45 degrees.
      Ask FixBot
    2. Samsung RC512 RAM Replacement: step 5, image 1 of 2 Samsung RC512 RAM Replacement: step 5, image 2 of 2
      • Carefully slide the RAM away from the slot to remove it.
      • Repeat step 4 to remove another RAM.
      Ask FixBot
Author
with
jando
923 Reputation
8 Guides authored
USF Tampa, Team 18-2, Blackwell Fall 2016 Member of USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 82
All Time: 1,036
