Samsung RC512 Optic Drive Replacement
    1. Samsung RC512 Optic Drive Replacement, Battery: step 1, image 1 of 1
      • Place the laptop upside down.
      Ask FixBot
    2. Samsung RC512 Optic Drive Replacement: step 2, image 1 of 2 Samsung RC512 Optic Drive Replacement: step 2, image 2 of 2
      • Locate two notches above the battery.
      • Slide both battery locking notches to either side to remove the battery.
      • Pull the battery out.
      Ask FixBot
    1. Samsung RC512 Optic Drive Replacement, Back Panel: step 3, image 1 of 3 Samsung RC512 Optic Drive Replacement, Back Panel: step 3, image 2 of 3 Samsung RC512 Optic Drive Replacement, Back Panel: step 3, image 3 of 3
      • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
      • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
      • Carefully remove the back panel..
      Ask FixBot
    1. Samsung RC512 Optic Drive Replacement, Optic Drive: step 4, image 1 of 1
      • Remove the 4mm Phillips #0 screw using a Phillips #0 screwdriver.
      Ask FixBot
    2. Samsung RC512 Optic Drive Replacement: step 5, image 1 of 3 Samsung RC512 Optic Drive Replacement: step 5, image 2 of 3 Samsung RC512 Optic Drive Replacement: step 5, image 3 of 3
      • Use the spudger or fingers to gently pull the optical drive out.
      • Slide the optic drive away from the laptop.
      Ask FixBot
jando
923 Reputation
8 Guides authored
USF Tampa, Team 18-2, Blackwell Fall 2016 Member of USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 110
All Time: 756
