Samsung RC512 HDD Replacement
    1. Samsung RC512 HDD Replacement, Battery: step 1, image 1 of 1
      • Place the laptop upside down.
      Ask FixBot
    2. Samsung RC512 HDD Replacement: step 2, image 1 of 2 Samsung RC512 HDD Replacement: step 2, image 2 of 2
      • Locate two notches above the battery.
      • Slide both battery locking notches to either side to remove the battery.
      • Pull the battery out.
      Ask FixBot
    1. Samsung RC512 HDD Replacement, Back Panel: step 3, image 1 of 3 Samsung RC512 HDD Replacement, Back Panel: step 3, image 2 of 3 Samsung RC512 HDD Replacement, Back Panel: step 3, image 3 of 3
      • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
      • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
      • Carefully remove the back panel..
      Ask FixBot
    1. Samsung RC512 HDD Replacement, HDD: step 4, image 1 of 1
      • Carefully lift the HDD up using plastic opening tool.
      Ask FixBot
    2. Samsung RC512 HDD Replacement: step 5, image 1 of 1
      • Grab the HDD and connector.
      • Carefully pull the HDD away from the connector.
      Ask FixBot
    3. Samsung RC512 HDD Replacement: step 6, image 1 of 1
      • Take out the HDD and leave the connector in the laptop
      Ask FixBot
jando
923 Reputation
8 Guides authored
USF Tampa, Team 18-2, Blackwell Fall 2016 Member of USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 98
All Time: 1,491
