Up to 20% off select tools
Samsung Q330 Keyboard Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
70
All Time:
797
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
Hello everyone, in this guide I`ll be showing you how to open the laptop in order to change the keyboard.
    1. Samsung Q330 Keyboard Replacement, Opening the back panel.: step 1, image 1 of 2 Samsung Q330 Keyboard Replacement, Opening the back panel.: step 1, image 2 of 2
      • Unscrew all the screws holding the back panel in place.
      • Remove the battery and the small panel to reveal more screws.
      • Remove the HDD and RAM.
      • Slide out the DVD drive.
      Ask FixBot
    2. Samsung Q330 Keyboard Replacement, The insides.: step 2, image 1 of 2 Samsung Q330 Keyboard Replacement, The insides.: step 2, image 2 of 2
      • Unscrew the heatsink and fan assembly. Disconnect the fan and remove it.
      • Remove the screws that hold the motherboard in place
      • Disconnect the touchpad, keyboard, USB module and Wi-Fi module.
      • Disconnect the power, screen and speaker connectors.
      • Unscrew the hinges and remove the display.
      • Remove the motherboard.
      Ask FixBot
    3. Samsung Q330 Keyboard Replacement, Replacing the keyboard.: step 3, image 1 of 3 Samsung Q330 Keyboard Replacement, Replacing the keyboard.: step 3, image 2 of 3 Samsung Q330 Keyboard Replacement, Replacing the keyboard.: step 3, image 3 of 3
      • Peel and remove the black cover.
      • Use a soldering iron with a big tip, to melt the plastic rivets that hold the metal case for the keyboard.
      • Use a prying tool the remove the metal case.
      • Remove the old keyboard, place the new one and dont forget to place the metal case on top of it.
      • You can reuse the black cover is you want.
      Ask FixBot
Author
with
Simeon Brankov
10,569 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 70
All Time: 797
