Samsung PL200 Motherboard Replacement
    1. Samsung PL200 Motherboard Replacement, Motherboard: step 1, image 1 of 2 Samsung PL200 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      Tool used on this step:
      Phillips #000 Screwdriver
      $5.49
      Buy
      • Before you begin, turn off the camera and remove the battery and SD card.
      • Remove the two 3mm black external screws from the camera's right side using the #000 Phillips screwdriver.
      • Remove the five 3mm silver external screws from the bottom and left side of the camera using the #000 Phillips screwdriver.
      Ask FixBot
    2. Samsung PL200 Motherboard Replacement: step 2, image 1 of 3 Samsung PL200 Motherboard Replacement: step 2, image 2 of 3 Samsung PL200 Motherboard Replacement: step 2, image 3 of 3
      iFixit Opening Tool
      $1.99
      Buy
      Ask FixBot
    3. Samsung PL200 Motherboard Replacement: step 3, image 1 of 3 Samsung PL200 Motherboard Replacement: step 3, image 2 of 3 Samsung PL200 Motherboard Replacement: step 3, image 3 of 3
      $5.49
      Buy
      • Remove the 3mm screw holding the circuit board using the Phillips #000 screwdriver.
      • Using tweezers, unplug the wires from the circuit board and remove the circuit board.
      Ask FixBot
    4. Samsung PL200 Motherboard Replacement: step 4, image 1 of 2 Samsung PL200 Motherboard Replacement: step 4, image 2 of 2
      $5.49
      Buy
      Ask FixBot
    5. Samsung PL200 Motherboard Replacement: step 5, image 1 of 2 Samsung PL200 Motherboard Replacement: step 5, image 2 of 2
      Buy
      • Use tweezers to lift the black latch that connects the screen and motherboard. Gently pull the cord to disconnect the screen.
      • Separate the screen and the metal brace from the camera's body.
      Ask FixBot
    6. Samsung PL200 Motherboard Replacement: step 6, image 1 of 1
      iFixit Opening Tool
      $1.99
      Buy
      Ask FixBot
    7. Samsung PL200 Motherboard Replacement: step 7, image 1 of 1
      $5.49
      Buy
      • Use the Phillips #000 screwdriver to remove the two silver 3mm screws. These hold the motherboard in place.
      • If the motherboard has black tape on it, remove it with the tweezers.
      Ask FixBot
    8. Samsung PL200 Motherboard Replacement: step 8, image 1 of 3 Samsung PL200 Motherboard Replacement: step 8, image 2 of 3 Samsung PL200 Motherboard Replacement: step 8, image 3 of 3
      Buy
      • Continue using the tweezers to remove any black tape present.
      • Use the tweezers to disconnect the lens unit cord that is at the bottom of the camera below the motherboard.
      • Use the Phillips #000 screwdriver to remove the final silver 3mm screw that holds the motherboard in place.
      Ask FixBot
    9. Samsung PL200 Motherboard Replacement: step 9, image 1 of 3 Samsung PL200 Motherboard Replacement: step 9, image 2 of 3 Samsung PL200 Motherboard Replacement: step 9, image 3 of 3
      Buy
      • Use the tweezers to unplug the small lens unit cord from the back side of the camera's frame.
      • Separate the lens unit, motherboard, and camera.
      Ask FixBot
    10. Samsung PL200 Motherboard Replacement: step 10, image 1 of 3 Samsung PL200 Motherboard Replacement: step 10, image 2 of 3 Samsung PL200 Motherboard Replacement: step 10, image 3 of 3
      Buy
      • Use the tweezers to remove the small cord from the motherboard.
      • Use the tweezers to remove the first large lens unit cord from the motherboard.
      • Use the tweezers to remove the second large lens unit cord from the motherboard.
      Ask FixBot
    11. Samsung PL200 Motherboard Replacement: step 11, image 1 of 2 Samsung PL200 Motherboard Replacement: step 11, image 2 of 2
      FixHub Portable Soldering Station
      $249.95
      Buy
      • Using the soldering iron, desolder the four wires from the old motherboard.
      Ask FixBot
    12. Samsung PL200 Motherboard Replacement: step 12, image 1 of 2 Samsung PL200 Motherboard Replacement: step 12, image 2 of 2
      $249.95
      Buy
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards-certified recycler.
Marcus Lee
101 Reputation
1 Guide authored
Clemson, Team 15-7, Shirley Winter 2015 Member of Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 37
All Time: 1,101
