Up to 20% off select tools
Samsung PL200 Lens Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
136
All Time:
2,205
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 40 minutes
Difficulty: Difficult
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
This guide allows you to replace the lens on your Samsung Pl200 camera. To complete this guide you will need a #000 Phillips Screwdriver, a Plastic Opening Tool, and a set of Tweezers.
    1. Samsung PL200 Lens Replacement, Battery: step 1, image 1 of 2 Samsung PL200 Lens Replacement, Battery: step 1, image 2 of 2
      • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
      • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/SD card compartment door. Once opened, the battery should be visible.
      Ask FixBot
    2. Samsung PL200 Lens Replacement: step 2, image 1 of 3 Samsung PL200 Lens Replacement: step 2, image 2 of 3 Samsung PL200 Lens Replacement: step 2, image 3 of 3
      • Once the battery/SD card compartment is opened, in order to remove the battery, you must push the small blue release button.
      • This will release the spring loaded battery.
      • Use your fingers to remove the old battery.
      Ask FixBot
    3. Samsung PL200 Lens Replacement: step 3, image 1 of 3 Samsung PL200 Lens Replacement: step 3, image 2 of 3 Samsung PL200 Lens Replacement: step 3, image 3 of 3
      • Insert the new battery into the battery slot.
      • Push it down with your finger until the blue release switch re-engages over top of the battery.
      • Close the battery/SD card compartment.
      Ask FixBot
    1. Samsung PL200 Lens Replacement, LCD Screen: step 4, image 1 of 1
      • Remove the six 3 mm external screws from the camera base using the Phillips #000 screwdriver.
      Ask FixBot
    2. Samsung PL200 Lens Replacement: step 5, image 1 of 3 Samsung PL200 Lens Replacement: step 5, image 2 of 3 Samsung PL200 Lens Replacement: step 5, image 3 of 3
      • Use the plastic opening tools and your fingers to pull the external cover off.
      Ask FixBot
    3. Samsung PL200 Lens Replacement: step 6, image 1 of 2 Samsung PL200 Lens Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the 3 mm screw holding the circuit board.
      • Use a pair of tweezers to detach the two ribbon cables connecting the circuit board to the camera.
      • Remove the circuit board.
      Ask FixBot
    4. Samsung PL200 Lens Replacement: step 7, image 1 of 2 Samsung PL200 Lens Replacement: step 7, image 2 of 2
      • Flip the LCD screen forward and remove the two 3 mm screws holding the metal midframe using a Phillips #000 screwdriver.
      • Remove the midframe using an opening tool.
      Ask FixBot
    5. Samsung PL200 Lens Replacement: step 8, image 1 of 1
      • Remove the front cover. It will come off fairly easily.
      Ask FixBot
    6. Samsung PL200 Lens Replacement: step 9, image 1 of 2 Samsung PL200 Lens Replacement: step 9, image 2 of 2
      • Lift the black strip and the ribbon will easily come out.
      • After doing this, the LCD screen will be separated from the camera.
      Ask FixBot
    1. Samsung PL200 Lens Replacement, SD Card: step 10, image 1 of 2 Samsung PL200 Lens Replacement, SD Card: step 10, image 2 of 2
      • Push the battery cover over to access battery/SD card compartment on the bottom.
      • There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
      • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
      Ask FixBot
    2. Samsung PL200 Lens Replacement: step 11, image 1 of 2 Samsung PL200 Lens Replacement: step 11, image 2 of 2
      • Once the battery/SD card compartment is opened, simply push the SD card down to activate the spring loaded ejector to raise SD card.
      • Use your fingers to remove the old SD card.
      • Insert the new SD card into the SD card slot and push it down all the way until it clicks and remains flush with battery.
      Ask FixBot
    1. Samsung PL200 Lens Replacement, Lens: step 12, image 1 of 2 Samsung PL200 Lens Replacement, Lens: step 12, image 2 of 2
      • Remove the two black 3 mm screws from the right side of the camera using a Phillips #000 screwdriver.
      • Remove the five silver 3 mm screws from the camera's side and bottom using a Phillips #000 screwdriver.
      Ask FixBot
    2. Samsung PL200 Lens Replacement: step 13, image 1 of 2 Samsung PL200 Lens Replacement: step 13, image 2 of 2
      • Use a plastic opening tool and your fingers to pry off the external cover.
      Ask FixBot
    3. Samsung PL200 Lens Replacement: step 14, image 1 of 3 Samsung PL200 Lens Replacement: step 14, image 2 of 3 Samsung PL200 Lens Replacement: step 14, image 3 of 3
      Buy
      • Remove the single 3 mm screw securing the circuit board with a Phillips #000 screwdriver.
      • Remove any leftover tape on the circuit board and screen.
      • Unplug and remove the wires from the circuit board using a set of tweezers.
      Ask FixBot
    4. Samsung PL200 Lens Replacement: step 15, image 1 of 2 Samsung PL200 Lens Replacement: step 15, image 2 of 2
      • Flip the LCD screen forward and out to the side.
      • Use a Phillips #000 screwdriver to remove the two 3 mm screws beneath the LCD screen.
      • Remove the metal brace using the Plastic Opening Tool.
      Ask FixBot
    5. Samsung PL200 Lens Replacement: step 16, image 1 of 2 Samsung PL200 Lens Replacement: step 16, image 2 of 2
      • Flip the ZIF connector's locking bar vertically, then gently remove the ribbon cable.
      • Remove the screen.
      Ask FixBot
    6. Samsung PL200 Lens Replacement: step 17, image 1 of 1
      • Remove the front cover of the camera using your fingers and a plastic opening tool.
      Ask FixBot
    7. Samsung PL200 Lens Replacement: step 18, image 1 of 1
      • Set the screen and metal brace aside.
      • Open the camera’s battery compartment on the bottom part of the camera.
      Ask FixBot
    8. Samsung PL200 Lens Replacement: step 19, image 1 of 1
      • Remove the two 3 mm corner screws that secure the motherboard, with a Phillips #000 screwdriver.
      • Remove any leftover tape that may still be on the motherboard.
      Ask FixBot
    9. Samsung PL200 Lens Replacement: step 20, image 1 of 3 Samsung PL200 Lens Replacement: step 20, image 2 of 3 Samsung PL200 Lens Replacement: step 20, image 3 of 3
      • Use tweezers to remove the tape from the bottom of the camera.
      • Then use the tweezers to disconnect the lens unit cord at the bottom of the camera from the motherboard.
      • Remove the last 3 mm screw securing the motherboard with a Phillips #00 screwdriver.
      Ask FixBot
    10. Samsung PL200 Lens Replacement: step 21, image 1 of 3 Samsung PL200 Lens Replacement: step 21, image 2 of 3 Samsung PL200 Lens Replacement: step 21, image 3 of 3
      • Use tweezers to unplug the small lens unit cord from the camera frame on the backside of the camera.
      • Gently lift the lens unit from the frame.
      • Separate the lens unit, motherboard, and camera.
      Ask FixBot
    11. Samsung PL200 Lens Replacement: step 22, image 1 of 3 Samsung PL200 Lens Replacement: step 22, image 2 of 3 Samsung PL200 Lens Replacement: step 22, image 3 of 3
      • Use tweezers to disconnect the small ribbon cable from the motherboard.
      • Then use the tweezers to remove the first large lens unit ribbon cable from the motherboard.
      • Finally, use the tweezers to remove the second large lens unit ribbon cable from the motherboard.
      Ask FixBot
    12. Samsung PL200 Lens Replacement: step 23, image 1 of 1
      • You have now separated the lens unit. Replace it with a functional lens unit at this stage, and reassemble the device.
      Ask FixBot
2 other people completed this guide.
Author
with
Weston Tracey
178 Reputation
1 Guide authored
Clemson, Team 15-7, Shirley Winter 2015 Member of Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 136
All Time: 2,205
