Up to 20% off select tools
Samsung PL200 LCD Screen Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
122
All Time:
1,561
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Replace a broken, cracked or frozen screen on your Samsung PL200 digital camera. Tools are required to access interior camera components.
    1. Samsung PL200 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • Remove the six 3 mm external screws from the camera base using the Phillips #000 screwdriver.
      Ask FixBot
    2. Samsung PL200 LCD Screen Replacement: step 2, image 1 of 3 Samsung PL200 LCD Screen Replacement: step 2, image 2 of 3 Samsung PL200 LCD Screen Replacement: step 2, image 3 of 3
      • Use the plastic opening tools and your fingers to pull the external cover off.
      Ask FixBot
    3. Samsung PL200 LCD Screen Replacement: step 3, image 1 of 2 Samsung PL200 LCD Screen Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the 3 mm screw holding the circuit board.
      • Use a pair of tweezers to detach the two ribbon cables connecting the circuit board to the camera.
      • Remove the circuit board.
      Ask FixBot
    4. Samsung PL200 LCD Screen Replacement: step 4, image 1 of 2 Samsung PL200 LCD Screen Replacement: step 4, image 2 of 2
      • Flip the LCD screen forward and remove the two 3 mm screws holding the metal midframe using a Phillips #000 screwdriver.
      • Remove the midframe using an opening tool.
      Ask FixBot
    5. Samsung PL200 LCD Screen Replacement: step 5, image 1 of 1
      • Remove the front cover. It will come off fairly easily.
      Ask FixBot
    6. Samsung PL200 LCD Screen Replacement: step 6, image 1 of 2 Samsung PL200 LCD Screen Replacement: step 6, image 2 of 2
      • Lift the black strip and the ribbon will easily come out.
      • After doing this, the LCD screen will be separated from the camera.
      Ask FixBot
Author
with
Jacob Presnell
219 Reputation
2 Guides authored
Clemson, Team 15-7, Shirley Winter 2015 Member of Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 122
All Time: 1,561
