Up to 20% off select tools
Samsung PL200 Battery Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
8
Past 7 Days:
23
Past 30 Days:
121
All Time:
2,572
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Very easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
This is a simple replacement, requiring no tools.
    1. Samsung PL200 Battery Replacement, Battery: step 1, image 1 of 2 Samsung PL200 Battery Replacement, Battery: step 1, image 2 of 2
      • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
      • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/SD card compartment door. Once opened, the battery should be visible.
      Ask FixBot
    2. Samsung PL200 Battery Replacement: step 2, image 1 of 3 Samsung PL200 Battery Replacement: step 2, image 2 of 3 Samsung PL200 Battery Replacement: step 2, image 3 of 3
      • Once the battery/SD card compartment is opened, in order to remove the battery, you must push the small blue release button.
      • This will release the spring loaded battery.
      • Use your fingers to remove the old battery.
      Ask FixBot
    3. Samsung PL200 Battery Replacement: step 3, image 1 of 3 Samsung PL200 Battery Replacement: step 3, image 2 of 3 Samsung PL200 Battery Replacement: step 3, image 3 of 3
      • Insert the new battery into the battery slot.
      • Push it down with your finger until the blue release switch re-engages over top of the battery.
      • Close the battery/SD card compartment.
      Ask FixBot
After replacing the battery, be sure to connect your charger cable and charge the new battery fully before using it.
Author
with
Austin Fitzpatrick
110 Reputation
1 Guide authored
Clemson, Team 15-7, Shirley Winter 2015 Member of Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
5 Members
60 Guides authored
2 Guide Comments
Is the battery dead? Can Samsung indicate wher new batteries are sold? Camera retailers are rare, these days
Reginald Parker - Reply Share
No-one can find a contact address for Samsung spares. New smartphones, no problem! Thank you for trying. I just have to keep looking! Reg
Past 24 Hours: 8
Past 7 Days: 23
Past 30 Days: 121
All Time: 2,572
