Up to 20% off select tools
Samsung PL20 Lens Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
12
Past 7 Days:
32
Past 30 Days:
154
All Time:
4,584
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove and replace a dysfunctional lens on the Samsung PL20 digital camera.
    1. Samsung PL20 Lens Replacement, Lens: step 1, image 1 of 3 Samsung PL20 Lens Replacement, Lens: step 1, image 2 of 3 Samsung PL20 Lens Replacement, Lens: step 1, image 3 of 3
      • Remove the battery and the memory card from the device.
      • Remove the two screws on the side of the device, to the left of the camera lens.
      Ask FixBot
    2. Samsung PL20 Lens Replacement: step 2, image 1 of 3 Samsung PL20 Lens Replacement: step 2, image 2 of 3 Samsung PL20 Lens Replacement: step 2, image 3 of 3
      • Remove the single screw from the bottom of the device.
      • Remove the two screws on the side of the the device, to the right of the camera lens.
      • Using a plastic opening tool, pry the outside casing apart. Start from the battery compartment and work around the seem of the casing.
      Ask FixBot
    3. Samsung PL20 Lens Replacement: step 3, image 1 of 3 Samsung PL20 Lens Replacement: step 3, image 2 of 3 Samsung PL20 Lens Replacement: step 3, image 3 of 3
      • Remove the back panel, revealing the LCD screen.
      • Pull the LCD screen out of its holder. Once you have access to the connecting strip, flip the clip upwards releasing the screen completely and remove.
      Ask FixBot
    4. Samsung PL20 Lens Replacement: step 4, image 1 of 3 Samsung PL20 Lens Replacement: step 4, image 2 of 3 Samsung PL20 Lens Replacement: step 4, image 3 of 3
      • Gently pull the front panel from the device.
      • Remove the two screws attaching the LCD screen holder to the device.
      • Remove the screen holder from the rest of the device.
      Ask FixBot
    5. Samsung PL20 Lens Replacement: step 5, image 1 of 3 Samsung PL20 Lens Replacement: step 5, image 2 of 3 Samsung PL20 Lens Replacement: step 5, image 3 of 3
      • Flip the grey clip upwards, releasing the connector from the device.
      • Disconnect the ribbon cable extending from the left side.
      • Disconnect the ribbon cable extending from the button bar.
      • Remove the 2 screws.
      Ask FixBot
    6. Samsung PL20 Lens Replacement: step 6, image 1 of 3 Samsung PL20 Lens Replacement: step 6, image 2 of 3 Samsung PL20 Lens Replacement: step 6, image 3 of 3
      • Remove these 3 screws. releasing the lens from the logic board.
      • Remove the lens from the logic board.
      Ask FixBot
Author
with
oldturkey03
867,026 Reputation
123 Guides authored
2 Guide Comments
Beware there is a capacitor that stores a charge even when the battery is removed. On my camera i touched it, it created a short circuit, i got a shock, and it killed my camera.
morrisettema - Reply Share
如果螺丝不慎遗失应该买多大的
742339702@qq.com - Reply Share
Past 24 Hours: 12
Past 7 Days: 32
Past 30 Days: 154
All Time: 4,584
