Tools
Introduction
Go to step 1 ↓Make sure you look at the Samsung P241 Troubleshooting Guide first to see if you can solve your problem without taking the DVD player apart.
If the button panel is broken a replacement button panel will need to be purchased.
With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
With the front of the DVD player facing you, turn the power on and eject the disc tray.
Press down on the disc tray with your thumbs while also pressing up with your pointer finger on the left and right edges of the silver cover. The cover should easily pop up and off the disc tray.
Holding the front panel so the Samsung logo is visible, rotate the panel to view the opposite side.
If the button panel is not the cause of the problem, the button sensors on the motherboard need to be replaced.
You can refer to this guide for directions on how to solder new sensors on your motherboard if you don't want to replace the entire motherboard.
