Samsung NaviBot SR8855 disassembly
    1. Samsung NaviBot SR8855 disassembly, Samsung NaviBot SR8855 disassembly: step 1, image 1 of 1
      • Remove the dust basket.
      Ask FixBot
    2. Samsung NaviBot SR8855 disassembly: step 2, image 1 of 1
      • Move the switch to "0".
      • Unscrew the battery cover.
      Ask FixBot
    3. Samsung NaviBot SR8855 disassembly: step 3, image 1 of 1
      • Disconnect the battery and remove it.
      Ask FixBot
    4. Samsung NaviBot SR8855 disassembly: step 4, image 1 of 1
      • Remove the 2 screws and 2 plastic pieces.
      Ask FixBot
    5. Samsung NaviBot SR8855 disassembly: step 5, image 1 of 1
      • Withdraw the front guard.
      • Disconnect the connector.
      Ask FixBot
    6. Samsung NaviBot SR8855 disassembly: step 6, image 1 of 1
      • Remove the guards on each side.
      Ask FixBot
    7. Samsung NaviBot SR8855 disassembly: step 7, image 1 of 1
      • Remove the 2 screws and the cover on each side.
      Ask FixBot
    8. Samsung NaviBot SR8855 disassembly: step 8, image 1 of 1
      • Remove the 2 screws.
      Ask FixBot
    9. Samsung NaviBot SR8855 disassembly: step 9, image 1 of 1
      • Slide the top upwards (watch out for 4 clips).
      Ask FixBot
    10. Samsung NaviBot SR8855 disassembly: step 10, image 1 of 1
      • Remove the 6 screws.
      Ask FixBot
    11. Samsung NaviBot SR8855 disassembly: step 11, image 1 of 1
      • Take off the top cover, and there you have it - your NaviBot is dismantled!
      Ask FixBot
30 other people completed this guide.
Special thanks to these translators:
fr en
100%
Philip Le Riche is helping us fix the world! Want to contribute?
Start translating ›
martinuk
818 Reputation
1 Guide authored
27 Guide Comments
Bonjour. Sur quel site avez vous trouvé le contacteur?
Merci!
Gilles
drgheidrich - Reply Share
Super doc.
J'avais commencé seul, mais je bloquais, j'avais pas réussi à enlever le dessus .... etape 8 ;o)
Avec la doc, j'ai pu forcer plus...
Pareil, que la personne d'avant...
Pouvez vous m'indiquer ou vous avez trouvé le contacteur SVP
gfreu - Reply Share
Si ça peut aider du monde,
je viens de trouver la pièce ici
https://www.valpieces.fr/?gclid=CIrB-I60...
gfreu - Reply Share
Bravo, super doc !
Chez moi c'est l'aspiration qui défaille... à voir le mini moteur d'aspiration, on comprend que ce n'est pas vraiment un aspirateur cette machine ! Jusqu'à présent j'en étais super content cela dit (4 ans d'usage, une batterie changée, ce qui me semble normal si utilisé plus d'une fois par semaine...). Je vais tout nettoyer, et remonter, peut être tester le moteur... si je trouve le voltage de fonctionnement...
Bruno - Reply Share
Merci,
j'était vraiment coincé à a phase 8.
Il faut préciser de procéder en 2 étapes:
1 soulever à l'aide d'un couteau de chaque coté pour dé-clipser
2 faire coulisser vers l'avant.
J'avait une roue bloquée.
La poussière et surtout les cheveux arrivent quand même à se glisser à l'intérieur de la roue.
Il faut tout démonter et en profiter pour dépoussiérer tous les capteurs
Incroyable comme tout l'intérieur était sale.
Merci encore
john - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 119
All Time: 53,474
