Samsung NX300 Motherboard Replacement
  1. Samsung NX300 Motherboard Replacement, Unscrew the Back Panel: step 1, image 1 of 2 Samsung NX300 Motherboard Replacement, Unscrew the Back Panel: step 1, image 2 of 2
    • Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
    • On the NX300M model, there is an additional screw under the text AMOLED behind display which should be removed before detaching the back panel of the camera.
    Ask FixBot
  2. Samsung NX300 Motherboard Replacement, Remove the Input Port Screw: step 2, image 1 of 1
    • Using a Phillips #00 precision screwdriver, remove the last 4 mm screw located inside the input ports' compartment.
    Ask FixBot
  3. Samsung NX300 Motherboard Replacement, Open the Camera Casing: step 3, image 1 of 3 Samsung NX300 Motherboard Replacement, Open the Camera Casing: step 3, image 2 of 3 Samsung NX300 Motherboard Replacement, Open the Camera Casing: step 3, image 3 of 3
    • Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
    Ask FixBot
  4. Samsung NX300 Motherboard Replacement, Remove the Back Panel: step 4, image 1 of 3 Samsung NX300 Motherboard Replacement, Remove the Back Panel: step 4, image 2 of 3 Samsung NX300 Motherboard Replacement, Remove the Back Panel: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
    • To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
    Ask FixBot
  5. Samsung NX300 Motherboard Replacement, Unscrew the Motherboard: step 5, image 1 of 1
    • Using a Phillips #00 precision screwdriver, remove the three 4mm screws holding the motherboard in place.
    Ask FixBot
  6. Samsung NX300 Motherboard Replacement, Detach the Ribbons: step 6, image 1 of 3 Samsung NX300 Motherboard Replacement, Detach the Ribbons: step 6, image 2 of 3 Samsung NX300 Motherboard Replacement, Detach the Ribbons: step 6, image 3 of 3
    Buy
    • Using tweezers or a plastic opening tool, release the locks on the ribbon receptors by flicking up the black bars on the holds. Pull the five ribbons away from the motherboard (one hidden from view). This will free the motherboard completely from the device.
    Ask FixBot
  7. Samsung NX300 Motherboard Replacement: step 7, image 1 of 1
    • The motherboard is now free. Pull the motherboard up and slightly away from the input compartment; it will lift out easily.
    Ask FixBot
8 other people completed this guide.
Andres Perez
1,023 Reputation
5 Guides authored
USF Tampa, Team 9-6, Blackwell Winter 2015 Member of USF Tampa, Team 9-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G6
4 Members
12 Guides authored
6 Guide Comments
any suggestions where to get the board? i oly found one on aliexpress for $100
Sergei Levitan - Reply Share
I have a nx300 that wont switch on (green power light flickers when battery inserted) do you know if there is an internal fuse which can be replaced?
cheers
Tom
Tom - Reply Share
I suggest you should buy a replacement motherboard to have your full functional operations.
yaksyari - Reply Share
What is the price of motheboard
nesphory assenga - Reply Share
Just replaced the tiny battery on the motherboard. Now I get the correct time and date with my photo’s. Nasty job soldering on the square millimeter, but it worked out fine.
Mad Edd - Reply Share
Past 24 Hours: 7
Past 7 Days: 12
Past 30 Days: 70
All Time: 5,886
