Up to 20% off select tools
Samsung NX30 Screen Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
25
Past 30 Days:
110
All Time:
2,818
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Parts
Tools
Introduction
Go to step 1 ↓
The replacement of your screen takes a little work. With the right equipment though it is not too difficult to do. Just be ready to unscrew a lot of screws.
    1. Samsung NX30 Screen Replacement, Battery: step 1, image 1 of 1
      • Flip the camera over so that the bottom of the camera is up.
      • Push the battery switch towards the back of the camera.
      Ask FixBot
    2. Samsung NX30 Screen Replacement: step 2, image 1 of 2 Samsung NX30 Screen Replacement: step 2, image 2 of 2
      • Locate the blue switch above the battery pack.
      • Slide the blue switch into the camera in the direction of the arrow on the switch. When the switch has been pushed in the battery will spring up.
      Ask FixBot
    3. Samsung NX30 Screen Replacement: step 3, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. Samsung NX30 Screen Replacement, Screen: step 4, image 1 of 3 Samsung NX30 Screen Replacement, Screen: step 4, image 2 of 3 Samsung NX30 Screen Replacement, Screen: step 4, image 3 of 3
      • Unscrew the nine 4mm Phillips head screws surrounding the body of the camera. They are located on the bottom of the camera and both sides of the camera.
      Ask FixBot
    2. Samsung NX30 Screen Replacement: step 5, image 1 of 3 Samsung NX30 Screen Replacement: step 5, image 2 of 3 Samsung NX30 Screen Replacement: step 5, image 3 of 3
      • Pull the viewer out from the camera and then up.
      • Unscrew the two black 4mm Phillips head screws under it.
      Ask FixBot
    3. Samsung NX30 Screen Replacement: step 6, image 1 of 2 Samsung NX30 Screen Replacement: step 6, image 2 of 2
      • Once the screws are all removed, place the camera face down, with the screen facing up.
      • Pry open the body using the plastic opening tool.
      • Gently open the body.
      Ask FixBot
    4. Samsung NX30 Screen Replacement: step 7, image 1 of 2 Samsung NX30 Screen Replacement: step 7, image 2 of 2
      • Then use the plastic opening tool to dislodge the Ribbon Cable, located near the top of the camera, from the Circuit Board.
      • The Ribbon Cable will be disconnected from the Circuit Board when you are done.
      Ask FixBot
Author
with
Julia Kilcup
431 Reputation
3 Guides authored
UW Tacoma, Team 1-4, Rose Winter 2016 Member of UW Tacoma, Team 1-4, Rose Winter 2016
UWT-ROSE-W16S1G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 110
All Time: 2,818
