Up to 20% off select tools
Samsung NX2000 LCD Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
110
All Time:
1,753
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide will help you learn how to replace the LCD of Samsung NX2000. It will show you the step by step procedures for removing the display successfully. Be sure to use the correct tool that is safe for the removal and does not damage the device.
    1. Samsung NX2000 LCD Replacement, LCD: step 1, image 1 of 1
      • First begin by flipping your camera upside down.
      • Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
      • Remember to store the screws in a secure place.
      Ask FixBot
    2. Samsung NX2000 LCD Replacement: step 2, image 1 of 3 Samsung NX2000 LCD Replacement: step 2, image 2 of 3 Samsung NX2000 LCD Replacement: step 2, image 3 of 3
      • Insert a plastic opening tool into the gab between the camera body and the back panel. Carefully pry open the camera and separate the back panel.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
    3. Samsung NX2000 LCD Replacement: step 3, image 1 of 3 Samsung NX2000 LCD Replacement: step 3, image 2 of 3 Samsung NX2000 LCD Replacement: step 3, image 3 of 3
      • Before taking it apart you'll have to detach the display ribbon cable.
      • Use a plastic opening tool, lift up the black strip to release the ribbon cable from the connector.
      Ask FixBot
    4. Samsung NX2000 LCD Replacement: step 4, image 1 of 3 Samsung NX2000 LCD Replacement: step 4, image 2 of 3 Samsung NX2000 LCD Replacement: step 4, image 3 of 3
      • Separate the LCD half compartment of the camera from the main body.
      Ask FixBot
    5. Samsung NX2000 LCD Replacement: step 5, image 1 of 1
      • Remove the four 1mm screws with the Y0 screwdriver.
      Ask FixBot
    6. Samsung NX2000 LCD Replacement: step 6, image 1 of 3 Samsung NX2000 LCD Replacement: step 6, image 2 of 3 Samsung NX2000 LCD Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
      • Detach the two ribbon cables, by first lifting the black tab on top of the connector.
      • Pull the ribbon cables out of the connectors with tweezers or two fingers.
      Ask FixBot
    7. Samsung NX2000 LCD Replacement: step 7, image 1 of 3 Samsung NX2000 LCD Replacement: step 7, image 2 of 3 Samsung NX2000 LCD Replacement: step 7, image 3 of 3
      • Place blue plastic spudger in between LCD screen and plastic surrounding.
      • Begin to lift up slowly, removing the LCD screen from the main frame.
      Ask FixBot
    8. Samsung NX2000 LCD Replacement: step 8, image 1 of 1
      • The LCD screen is now separated form the main frame.
      Ask FixBot
2 other people completed this guide.
Author
with
Maria Zamora
155 Reputation
1 Guide authored
USF Tampa, Team 7-4, Cheng Spring 2016 Member of USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 110
All Time: 1,753
