Up to 20% off select tools
Samsung NX2000 Battery Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
116
All Time:
1,788
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your camera is not turning on no matter how many times you charge it, it might be time for a battery replacement. This guide will help you replace your battery.
    1. Samsung NX2000 Battery Replacement, Battery: step 1, image 1 of 1
      • Place the camera upside down with the lens facing you.
      Ask FixBot
    2. Samsung NX2000 Battery Replacement: step 2, image 1 of 1
      • Locate the sliding latch on the right side of the camera and slide the latch to the left side to open up the battery compartment.
      Ask FixBot
    3. Samsung NX2000 Battery Replacement: step 3, image 1 of 1
      • Locate the blue release lever holding the battery down. Slide the blue lever to the right to release the battery itself.
      Ask FixBot
    4. Samsung NX2000 Battery Replacement: step 4, image 1 of 1
      • The battery will now slide up about an inch allowing the battery to be pulled out of the camera.
      Ask FixBot
    5. Samsung NX2000 Battery Replacement: step 5, image 1 of 1
      • Insert the new battery with the arrow on the battery pointing into the camera. The red square indicates the location of the arrow.
      Ask FixBot
Author
with
David Edbom
119 Reputation
1 Guide authored
USF Tampa, Team 7-4, Cheng Spring 2016 Member of USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 116
All Time: 1,788
