Samsung NX1000 Front Lens Cover Replacement
    1. Samsung NX1000 Front Lens Cover Replacement, Front Lens Cover: step 1, image 1 of 2 Samsung NX1000 Front Lens Cover Replacement, Front Lens Cover: step 1, image 2 of 2
      • Unscrew the four 5.5 mm #000 Philips screws that are on the metal ring with a Philips #000 screwdriver.
      Ask FixBot
    2. Samsung NX1000 Front Lens Cover Replacement: step 2, image 1 of 2 Samsung NX1000 Front Lens Cover Replacement: step 2, image 2 of 2
      • Remove the metal ring using the plastic opening tool.
      Ask FixBot
    3. Samsung NX1000 Front Lens Cover Replacement: step 3, image 1 of 2 Samsung NX1000 Front Lens Cover Replacement: step 3, image 2 of 2
      • Remove the black plastic ring using the plastic opening tool.
      Ask FixBot
    4. Samsung NX1000 Front Lens Cover Replacement: step 4, image 1 of 2 Samsung NX1000 Front Lens Cover Replacement: step 4, image 2 of 2
      • Remove the thin metal ring.
      Ask FixBot
    5. Samsung NX1000 Front Lens Cover Replacement: step 5, image 1 of 1
      • Remove the three 4.5 mm Phillips #000 head screws located inside the cover with a Phillips #000 screwdriver.
      Ask FixBot
    6. Samsung NX1000 Front Lens Cover Replacement: step 6, image 1 of 2 Samsung NX1000 Front Lens Cover Replacement: step 6, image 2 of 2
      • There are a few loose metal parts and springs. Be careful not to shake the device.
      • Remove the white plastic ring.
      Ask FixBot
Yesenia
717 Reputation
6 Guides authored
Cal Poly, Team 20-13, Maness Winter 2015 Member of Cal Poly, Team 20-13, Maness Winter 2015
CPSU-MANESS-W15S20G13
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 37
All Time: 2,810
