Samsung NX1 LCD Touch Screen Replacement
    1. Samsung NX1 LCD Touch Screen Replacement, Viewfinder Focus Dial: step 1, image 1 of 2 Samsung NX1 LCD Touch Screen Replacement, Viewfinder Focus Dial: step 1, image 2 of 2
      • Push the rubber viewfinder grip upward.
      Ask FixBot
    2. Samsung NX1 LCD Touch Screen Replacement: step 2, image 1 of 2 Samsung NX1 LCD Touch Screen Replacement: step 2, image 2 of 2
      • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
      • Remove the dial by lifting upward with your fingers.
      Ask FixBot
    1. Samsung NX1 LCD Touch Screen Replacement, Back Cover: step 3, image 1 of 3 Samsung NX1 LCD Touch Screen Replacement, Back Cover: step 3, image 2 of 3 Samsung NX1 LCD Touch Screen Replacement, Back Cover: step 3, image 3 of 3
      • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
      • Use your fingers to lift the plastic viewfinder cover upward.
      Ask FixBot
    2. Samsung NX1 LCD Touch Screen Replacement: step 4, image 1 of 2 Samsung NX1 LCD Touch Screen Replacement: step 4, image 2 of 2
      • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
      Ask FixBot
    3. Samsung NX1 LCD Touch Screen Replacement: step 5, image 1 of 1
      • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
      Ask FixBot
    4. Samsung NX1 LCD Touch Screen Replacement: step 6, image 1 of 1
      • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
      • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
      Ask FixBot
    5. Samsung NX1 LCD Touch Screen Replacement: step 7, image 1 of 3 Samsung NX1 LCD Touch Screen Replacement: step 7, image 2 of 3 Samsung NX1 LCD Touch Screen Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to separate the back cover from the front cover.
      • Pry the back cover in this order: bottom, right side, left side.
      Ask FixBot
    6. Samsung NX1 LCD Touch Screen Replacement: step 8, image 1 of 2 Samsung NX1 LCD Touch Screen Replacement: step 8, image 2 of 2
      • Use your fingers to pull the back cover away from the front cover.
      • Do not completely separate the back cover from the front cover as two cables hold these components together.
      Ask FixBot
    7. Samsung NX1 LCD Touch Screen Replacement: step 9, image 1 of 3 Samsung NX1 LCD Touch Screen Replacement: step 9, image 2 of 3 Samsung NX1 LCD Touch Screen Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to pull the two ribbon cables horizontally out of their clips.
      Ask FixBot
    1. Samsung NX1 LCD Touch Screen Replacement, LCD Touch Screen: step 10, image 1 of 1
      • Use the Phillips #00 screwdriver to remove the seven screws (three silver 3.5 mm screws and four black 2.7 mm screws).
      Ask FixBot
    2. Samsung NX1 LCD Touch Screen Replacement: step 11, image 1 of 2 Samsung NX1 LCD Touch Screen Replacement: step 11, image 2 of 2
      Buy
      • Use tweezers to remove the glued rubber piece.
      Ask FixBot
    3. Samsung NX1 LCD Touch Screen Replacement: step 12, image 1 of 3 Samsung NX1 LCD Touch Screen Replacement: step 12, image 2 of 3 Samsung NX1 LCD Touch Screen Replacement: step 12, image 3 of 3
      • Use the Phillips #00 screwdriver to remove the four black 2.3 mm screws.
      • Use your fingers to separate the LCD screen from the folding mechanism.
      Ask FixBot
2 other people completed this guide.
Hannah Patrick
903 Reputation
6 Guides authored
USF Tampa, Team 1-4, Leahy Spring 2016 Member of USF Tampa, Team 1-4, Leahy Spring 2016
USFT-LEAHY-S16S1G4
3 Members
72 Guides authored
5 Guide Comments
Where can one buy a new screen?
Lourens Coetzee - Reply Share
Where to get new screen?
Jonathan Wood - Reply Share
Thanks! This guide is missing some steps and details once you open it up, but it was enough for me to get the job done. Thank you.
Once inside be super careful with the ribbon cables. One slides out the side and the cable labeled “Main” pops off the top. At first I thought I broke the Main cable. You’ll need to unhood the main cable from the frame before you can detach the LCD… and the LCD is glued on airtight to the articulating frame.
I ordered a new replacement LCD on ebay from S. Korea. Good luck to anyone else who has to do this. I killed my screen after a couple heavy rain storms.
drew - Reply Share
One more question: where can I order a display for the NX1?
Henning Marx - Reply Share
DID anyone have to fix a broken folding mechanism?
Daniele. Pianciola - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 37
All Time: 2,013
