Up to 20% off select tools
Samsung NX1 Back Cover Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
107
All Time:
1,750
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The back cover holds the screen in place and protects the internal components of the camera.
    1. Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: step 1, image 1 of 2 Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: step 1, image 2 of 2
      • Push the rubber viewfinder grip upward.
      Ask FixBot
    2. Samsung NX1 Back Cover Replacement: step 2, image 1 of 2 Samsung NX1 Back Cover Replacement: step 2, image 2 of 2
      • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
      • Remove the dial by lifting upward with your fingers.
      Ask FixBot
    1. Samsung NX1 Back Cover Replacement, Back Cover: step 3, image 1 of 3 Samsung NX1 Back Cover Replacement, Back Cover: step 3, image 2 of 3 Samsung NX1 Back Cover Replacement, Back Cover: step 3, image 3 of 3
      • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
      • Use your fingers to lift the plastic viewfinder cover upward.
      Ask FixBot
    2. Samsung NX1 Back Cover Replacement: step 4, image 1 of 2 Samsung NX1 Back Cover Replacement: step 4, image 2 of 2
      • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
      Ask FixBot
    3. Samsung NX1 Back Cover Replacement: step 5, image 1 of 1
      • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
      Ask FixBot
    4. Samsung NX1 Back Cover Replacement: step 6, image 1 of 1
      • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
      • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
      Ask FixBot
    5. Samsung NX1 Back Cover Replacement: step 7, image 1 of 3 Samsung NX1 Back Cover Replacement: step 7, image 2 of 3 Samsung NX1 Back Cover Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to separate the back cover from the front cover.
      • Pry the back cover in this order: bottom, right side, left side.
      Ask FixBot
    6. Samsung NX1 Back Cover Replacement: step 8, image 1 of 2 Samsung NX1 Back Cover Replacement: step 8, image 2 of 2
      • Use your fingers to pull the back cover away from the front cover.
      • Do not completely separate the back cover from the front cover as two cables hold these components together.
      Ask FixBot
    7. Samsung NX1 Back Cover Replacement: step 9, image 1 of 3 Samsung NX1 Back Cover Replacement: step 9, image 2 of 3 Samsung NX1 Back Cover Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to pull the two ribbon cables horizontally out of their clips.
      Ask FixBot
Author
with
Hannah Patrick
903 Reputation
6 Guides authored
USF Tampa, Team 1-4, Leahy Spring 2016 Member of USF Tampa, Team 1-4, Leahy Spring 2016
USFT-LEAHY-S16S1G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 107
All Time: 1,750
