Up to 20% off select tools
Samsung NX Mini Sensor Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
95
All Time:
2,107
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to access the sensor for cleaning or necessary repairs.
    1. Samsung NX Mini Sensor Replacement, Battery: step 1, image 1 of 3 Samsung NX Mini Sensor Replacement, Battery: step 1, image 2 of 3 Samsung NX Mini Sensor Replacement, Battery: step 1, image 3 of 3
      • Orient the camera so the button panel and LCD are facing you.
      • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
      Ask FixBot
    2. Samsung NX Mini Sensor Replacement: step 2, image 1 of 2 Samsung NX Mini Sensor Replacement: step 2, image 2 of 2
      • Push the blue trapdoor to the left to release the battery, and remove the battery.
      • There is no battery shown in this photo.
      Ask FixBot
    1. Samsung NX Mini Sensor Replacement, Front Case: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
      Ask FixBot
    2. Samsung NX Mini Sensor Replacement: step 4, image 1 of 1
      • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
      Ask FixBot
    3. Samsung NX Mini Sensor Replacement: step 5, image 1 of 1
      • Remove the four 5 mm Phillips #00 screws from the lens assembly.
      Ask FixBot
    4. Samsung NX Mini Sensor Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the metal lens mount by hand or with tweezers.
      • Be careful not to touch the sensor in the center of the lens assembly.
      Ask FixBot
    5. Samsung NX Mini Sensor Replacement: step 7, image 1 of 1
      • Use tweezers to remove the inner metal ring.
      Ask FixBot
    6. Samsung NX Mini Sensor Replacement: step 8, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
      Ask FixBot
    7. Samsung NX Mini Sensor Replacement: step 9, image 1 of 2 Samsung NX Mini Sensor Replacement: step 9, image 2 of 2
      • Use your hands to slowly pull the front casing away from the camera.
      • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
      Ask FixBot
    1. Samsung NX Mini Sensor Replacement, Sensor: step 10, image 1 of 3 Samsung NX Mini Sensor Replacement, Sensor: step 10, image 2 of 3 Samsung NX Mini Sensor Replacement, Sensor: step 10, image 3 of 3
      Buy
      • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
      • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
      • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
      • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
      Ask FixBot
    2. Samsung NX Mini Sensor Replacement: step 11, image 1 of 2 Samsung NX Mini Sensor Replacement: step 11, image 2 of 2
      • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
      Ask FixBot
    3. Samsung NX Mini Sensor Replacement: step 12, image 1 of 3 Samsung NX Mini Sensor Replacement: step 12, image 2 of 3 Samsung NX Mini Sensor Replacement: step 12, image 3 of 3
      • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
      • Remove the battery compartment.
      Ask FixBot
    4. Samsung NX Mini Sensor Replacement: step 13, image 1 of 2 Samsung NX Mini Sensor Replacement: step 13, image 2 of 2
      • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
      Ask FixBot
    5. Samsung NX Mini Sensor Replacement: step 14, image 1 of 1
      • Gently remove the sensor mount from the camera case.
      Ask FixBot
To reassemble your camera, follow these instructions in reverse order.
Author
with
Kelsea Weber
21,643 Reputation
32 Guides authored
1 Guide Comment
Hello,
I need to know the exact dimensions of the IR-cut filter in the Samsung NX Mini camera, which should be just above the sensor. Could you possibly give me that information? I need that because I’d like to modify my NX Mini camera and change it into an infrared camera. I have to cut an infrared filter in the right size, before the disassembly of the camera.
Thank you!
Siamak ADN - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 95
All Time: 2,107
