Up to 20% off select tools
Samsung NX Mini Front Case Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
108
All Time:
1,379
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a damaged front case or open the case to access other components of your camera.
    1. Samsung NX Mini Front Case Replacement, Battery: step 1, image 1 of 3 Samsung NX Mini Front Case Replacement, Battery: step 1, image 2 of 3 Samsung NX Mini Front Case Replacement, Battery: step 1, image 3 of 3
      • Orient the camera so the button panel and LCD are facing you.
      • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
      Ask FixBot
    2. Samsung NX Mini Front Case Replacement: step 2, image 1 of 2 Samsung NX Mini Front Case Replacement: step 2, image 2 of 2
      • Push the blue trapdoor to the left to release the battery, and remove the battery.
      • There is no battery shown in this photo.
      Ask FixBot
    1. Samsung NX Mini Front Case Replacement, Front Case: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
      Ask FixBot
    2. Samsung NX Mini Front Case Replacement: step 4, image 1 of 1
      • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
      Ask FixBot
    3. Samsung NX Mini Front Case Replacement: step 5, image 1 of 1
      • Remove the four 5 mm Phillips #00 screws from the lens assembly.
      Ask FixBot
    4. Samsung NX Mini Front Case Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the metal lens mount by hand or with tweezers.
      • Be careful not to touch the sensor in the center of the lens assembly.
      Ask FixBot
    5. Samsung NX Mini Front Case Replacement: step 7, image 1 of 1
      • Use tweezers to remove the inner metal ring.
      Ask FixBot
    6. Samsung NX Mini Front Case Replacement: step 8, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
      Ask FixBot
    7. Samsung NX Mini Front Case Replacement: step 9, image 1 of 2 Samsung NX Mini Front Case Replacement: step 9, image 2 of 2
      • Use your hands to slowly pull the front casing away from the camera.
      • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
      Ask FixBot
Author
with
Kelsea Weber
21,643 Reputation
32 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 108
All Time: 1,379
