Up to 20% off select tools
Samsung NX Mini Button Panel Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
98
All Time:
1,140
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is the button panel on your camera unresponsive? Are your buttons dirty, cracked or missing? This guide will show you how to access the button panel on your camera in order to make necessary repairs.
    1. Samsung NX Mini Button Panel Replacement, Battery: step 1, image 1 of 3 Samsung NX Mini Button Panel Replacement, Battery: step 1, image 2 of 3 Samsung NX Mini Button Panel Replacement, Battery: step 1, image 3 of 3
      • Orient the camera so the button panel and LCD are facing you.
      • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
      Ask FixBot
    2. Samsung NX Mini Button Panel Replacement: step 2, image 1 of 2 Samsung NX Mini Button Panel Replacement: step 2, image 2 of 2
      • Push the blue trapdoor to the left to release the battery, and remove the battery.
      • There is no battery shown in this photo.
      Ask FixBot
    1. Samsung NX Mini Button Panel Replacement, Front Case: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
      Ask FixBot
    2. Samsung NX Mini Button Panel Replacement: step 4, image 1 of 1
      • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
      Ask FixBot
    3. Samsung NX Mini Button Panel Replacement: step 5, image 1 of 1
      • Remove the four 5 mm Phillips #00 screws from the lens assembly.
      Ask FixBot
    4. Samsung NX Mini Button Panel Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the metal lens mount by hand or with tweezers.
      • Be careful not to touch the sensor in the center of the lens assembly.
      Ask FixBot
    5. Samsung NX Mini Button Panel Replacement: step 7, image 1 of 1
      • Use tweezers to remove the inner metal ring.
      Ask FixBot
    6. Samsung NX Mini Button Panel Replacement: step 8, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
      Ask FixBot
    7. Samsung NX Mini Button Panel Replacement: step 9, image 1 of 2 Samsung NX Mini Button Panel Replacement: step 9, image 2 of 2
      • Use your hands to slowly pull the front casing away from the camera.
      • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
      Ask FixBot
    1. Samsung NX Mini Button Panel Replacement, Sensor: step 10, image 1 of 3 Samsung NX Mini Button Panel Replacement, Sensor: step 10, image 2 of 3 Samsung NX Mini Button Panel Replacement, Sensor: step 10, image 3 of 3
      Buy
      • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
      • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
      • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
      • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
      Ask FixBot
    2. Samsung NX Mini Button Panel Replacement: step 11, image 1 of 2 Samsung NX Mini Button Panel Replacement: step 11, image 2 of 2
      • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
      Ask FixBot
    3. Samsung NX Mini Button Panel Replacement: step 12, image 1 of 3 Samsung NX Mini Button Panel Replacement: step 12, image 2 of 3 Samsung NX Mini Button Panel Replacement: step 12, image 3 of 3
      • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
      • Remove the battery compartment.
      Ask FixBot
    4. Samsung NX Mini Button Panel Replacement: step 13, image 1 of 2 Samsung NX Mini Button Panel Replacement: step 13, image 2 of 2
      • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
      Ask FixBot
    5. Samsung NX Mini Button Panel Replacement: step 14, image 1 of 1
      • Gently remove the sensor mount from the camera case.
      Ask FixBot
    1. Samsung NX Mini Button Panel Replacement, Motherboard: step 15, image 1 of 2 Samsung NX Mini Button Panel Replacement, Motherboard: step 15, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
      Ask FixBot
    2. Samsung NX Mini Button Panel Replacement: step 16, image 1 of 2 Samsung NX Mini Button Panel Replacement: step 16, image 2 of 2
      Buy
      • Use tweezers to disconnect the wifi antenna from the motherboard.
      Ask FixBot
    3. Samsung NX Mini Button Panel Replacement: step 17, image 1 of 3 Samsung NX Mini Button Panel Replacement: step 17, image 2 of 3 Samsung NX Mini Button Panel Replacement: step 17, image 3 of 3
      • Use a spudger to disconnect the LCD ribbon cable by prying it straight up from the motherboard.
      Ask FixBot
    4. Samsung NX Mini Button Panel Replacement: step 18, image 1 of 3 Samsung NX Mini Button Panel Replacement: step 18, image 2 of 3 Samsung NX Mini Button Panel Replacement: step 18, image 3 of 3
      • Use a spudger to unlock the topmost ZIF connector by flipping open the black flap.
      Ask FixBot
    5. Samsung NX Mini Button Panel Replacement: step 19, image 1 of 2 Samsung NX Mini Button Panel Replacement: step 19, image 2 of 2
      • Insert the pointed end of a spudger into the hole in the middle of the ribbon cable.
      • Gently pull the spudger back to slide the ribbon cable out of its connector.
      Ask FixBot
    6. Samsung NX Mini Button Panel Replacement: step 20, image 1 of 3 Samsung NX Mini Button Panel Replacement: step 20, image 2 of 3 Samsung NX Mini Button Panel Replacement: step 20, image 3 of 3
      • Disconnect the blue ribbon cable from the motherboard.
      • Insert the pointed end of a spudger into the hole in the top of the ribbon.
      • Gently pull the ribbon from the connector.
      Ask FixBot
    7. Samsung NX Mini Button Panel Replacement: step 21, image 1 of 1
      • Remove the motherboard from the camera.
      Ask FixBot
    1. Samsung NX Mini Button Panel Replacement, Button Panel: step 22, image 1 of 1
      • Remove the three 4 mm Phillips #00 screws securing the button panel to the camera case.
      Ask FixBot
    2. Samsung NX Mini Button Panel Replacement: step 23, image 1 of 1
      Buy
      • Use tweezers to lift the button panel cover away from the case.
      Ask FixBot
Author
with
Kelsea Weber
21,643 Reputation
32 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 98
All Time: 1,140
