Samsung NP700Z5AH Battery Replacement
    1. Samsung NP700Z5AH Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
      Ask FixBot
    2. Samsung NP700Z5AH Battery Replacement: step 2, image 1 of 3 Samsung NP700Z5AH Battery Replacement: step 2, image 2 of 3 Samsung NP700Z5AH Battery Replacement: step 2, image 3 of 3
      • Using your fingers, pinch the edge of the SD card and pull to remove it.
      Ask FixBot
    3. Samsung NP700Z5AH Battery Replacement: step 3, image 1 of 2 Samsung NP700Z5AH Battery Replacement: step 3, image 2 of 2
      • Wedge your fingers in between the upper case and the lower case
      • Gently pull the lower case away from the upper case to remove it
      Ask FixBot
    4. Samsung NP700Z5AH Battery Replacement: step 4, image 1 of 2 Samsung NP700Z5AH Battery Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
      • Be sure to pull straight backwards, or you risk damaging the wires.
      Ask FixBot
    5. Samsung NP700Z5AH Battery Replacement: step 5, image 1 of 1
      • Remove the two 4.4mm Phillips#00 screws from the battery case.
      Ask FixBot
    6. Samsung NP700Z5AH Battery Replacement: step 6, image 1 of 2 Samsung NP700Z5AH Battery Replacement: step 6, image 2 of 2
      • Place your fingers on the corner sections of the battery.
      • Lift to remove the battery.
      • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
      Ask FixBot
5 other people completed this guide.
1 Guide Comment
ifixit@distinctlydifferent.co.uk
Jacqueline - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 135
All Time: 1,852
