Samsung NP510R5E-A01UB Battery Replacement
    1. Samsung NP510R5E-A01UB Battery Replacement, Hard Drive: step 1, image 1 of 1
      • Make sure the device is powered off before beginning.
      • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
      Ask FixBot
    2. Samsung NP510R5E-A01UB Battery Replacement: step 2, image 1 of 1
      • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
      Ask FixBot
    3. Samsung NP510R5E-A01UB Battery Replacement: step 3, image 1 of 2 Samsung NP510R5E-A01UB Battery Replacement: step 3, image 2 of 2
      • Unplug the connector from the hard drive by pulling straight out.
      Ask FixBot
    1. Samsung NP510R5E-A01UB Battery Replacement, Battery: step 4, image 1 of 3 Samsung NP510R5E-A01UB Battery Replacement, Battery: step 4, image 2 of 3 Samsung NP510R5E-A01UB Battery Replacement, Battery: step 4, image 3 of 3
      • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
      • Unscrew the four silver 4.4mm long screws near the hard drive.
      • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
      Ask FixBot
    2. Samsung NP510R5E-A01UB Battery Replacement: step 5, image 1 of 3 Samsung NP510R5E-A01UB Battery Replacement: step 5, image 2 of 3 Samsung NP510R5E-A01UB Battery Replacement: step 5, image 3 of 3
      • Use the screwdriver to remove the four 3.5mm long screws holding the battery in place. Then carefully pull the battery's connector cable out to remove the battery.
      Ask FixBot
2 other people completed this guide.
Brian Briggs
529 Reputation
4 Guides authored
USF Tampa, Team S6-G5, Eyestone Spring 2018 Member of USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 43
All Time: 2,964
