Samsung NP36535C-S05US Key Replacement
    1. Samsung NP36535C-S05US Key Replacement, Battery: step 1, image 1 of 1
      • Turn the computer off.
      • Disconnect the charging cable from the laptop.
      • Failure to disconnect cable may result in electric shock.
      • Flip the laptop face down on a flat surface.
      Ask FixBot
    2. Samsung NP36535C-S05US Key Replacement: step 2, image 1 of 1
      • Slide the left and right switches to the unlock position.
      Ask FixBot
    3. Samsung NP36535C-S05US Key Replacement: step 3, image 1 of 2 Samsung NP36535C-S05US Key Replacement: step 3, image 2 of 2
      • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
      Ask FixBot
    1. Samsung NP36535C-S05US Key Replacement, Key: step 4, image 1 of 3 Samsung NP36535C-S05US Key Replacement, Key: step 4, image 2 of 3 Samsung NP36535C-S05US Key Replacement, Key: step 4, image 3 of 3
      • There is an outer and inner piece of the retainer. The outer retainer has two (2) grooves for the inner retainer's posts to sit in.
      • Place the inner retainer piece into the outer retainer piece by inserting the posts into the grooves on the outer retainer piece.
      Ask FixBot
    2. Samsung NP36535C-S05US Key Replacement: step 5, image 1 of 3 Samsung NP36535C-S05US Key Replacement: step 5, image 2 of 3 Samsung NP36535C-S05US Key Replacement: step 5, image 3 of 3
      Tool used on this step:
      $3.99
      Buy
      • There are two (2) grooves on the outer retainer that fit onto two (2) metal brackets on the key's designated space.
      • Use angled tweezers to place the assembled retainer onto the two (2) metal brackets on the keyboard.
      Ask FixBot
    3. Samsung NP36535C-S05US Key Replacement: step 6, image 1 of 3 Samsung NP36535C-S05US Key Replacement: step 6, image 2 of 3 Samsung NP36535C-S05US Key Replacement: step 6, image 3 of 3
      • Once the retainer is attached, press the key onto the retainer, it will make a snapping sound when in place.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 35
Past 30 Days: 57
All Time: 696
