Samsung NP36535C-S05US Display Screen Replacement
    1. Samsung NP36535C-S05US Display Screen Replacement, Battery: step 1, image 1 of 1
      • Turn the computer off.
      • Disconnect the charging cable from the laptop.
      • Failure to disconnect cable may result in electric shock.
      • Flip the laptop face down on a flat surface.
      Ask FixBot
    2. Samsung NP36535C-S05US Display Screen Replacement: step 2, image 1 of 1
      • Slide the left and right switches to the unlock position.
      Ask FixBot
    3. Samsung NP36535C-S05US Display Screen Replacement: step 3, image 1 of 2 Samsung NP36535C-S05US Display Screen Replacement: step 3, image 2 of 2
      • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
      Ask FixBot
    1. Samsung NP36535C-S05US Display Screen Replacement, Display Screen: step 4, image 1 of 3 Samsung NP36535C-S05US Display Screen Replacement, Display Screen: step 4, image 2 of 3 Samsung NP36535C-S05US Display Screen Replacement, Display Screen: step 4, image 3 of 3
      • Open the laptop.
      • Locate the two (2) screw covers.
      • Remove the screw covers with the metal spudger.
      Ask FixBot
    2. Samsung NP36535C-S05US Display Screen Replacement: step 5, image 1 of 1
      • Remove the two (2) 2.27 mm screws with the Philips #0 screwdriver.
      Ask FixBot
    3. Samsung NP36535C-S05US Display Screen Replacement: step 6, image 1 of 1
      • Carefully pry the front display cover off with a plastic prying tool.
      Ask FixBot
    4. Samsung NP36535C-S05US Display Screen Replacement: step 7, image 1 of 3 Samsung NP36535C-S05US Display Screen Replacement: step 7, image 2 of 3 Samsung NP36535C-S05US Display Screen Replacement: step 7, image 3 of 3
      • Locate the six (6) 2.39 mm screws on the display bracket.
      • Remove the four (4) screws on the left and right sides of the display bracket located near the base of the display with the Philips #0 screwdriver.
      • Remove the two (2) screws on the left and right sides of the display bracket located near the top of the display with the Phillips #0 screwdriver.
      Ask FixBot
    5. Samsung NP36535C-S05US Display Screen Replacement: step 8, image 1 of 1
      • Carefully remove the connector between the display and the display casing by pulling the connector away from its outlet.
      Ask FixBot
    6. Samsung NP36535C-S05US Display Screen Replacement: step 9, image 1 of 2 Samsung NP36535C-S05US Display Screen Replacement: step 9, image 2 of 2
      • Locate the six (6) 1.85 mm screws on the left and right brackets holding the display in place.
      • Remove the screws on each side of the bracket, alternating sides when removing each screw with the Philips #0 screwdriver.
      Ask FixBot
    7. Samsung NP36535C-S05US Display Screen Replacement: step 10, image 1 of 3 Samsung NP36535C-S05US Display Screen Replacement: step 10, image 2 of 3 Samsung NP36535C-S05US Display Screen Replacement: step 10, image 3 of 3
      • Locate the display connector on the back of the display.
      • Carefully remove the tape on the display connector.
      • Remove the display connector by unplugging it from its outlet.
      Ask FixBot
    8. Samsung NP36535C-S05US Display Screen Replacement: step 11, image 1 of 3 Samsung NP36535C-S05US Display Screen Replacement: step 11, image 2 of 3 Samsung NP36535C-S05US Display Screen Replacement: step 11, image 3 of 3
      • Locate and remove the tape from the back of the display in the two (2) sections marked on the supporting image.
      Ask FixBot
    9. Samsung NP36535C-S05US Display Screen Replacement: step 12, image 1 of 1
      • You have successfully removed the display screen.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 78
All Time: 812
