Samsung NP350V5C-T02US RAM Replacement
    1. Samsung NP350V5C-T02US RAM Replacement, ODD/HDD/Memory Cover: step 1, image 1 of 1
      • Flip the laptop over so that the bottom is facing toward you.
      Ask FixBot
    2. Samsung NP350V5C-T02US RAM Replacement: step 2, image 1 of 1
      • Using the Phillips #1 screwdriver, remove the M2.5X5 mm screw to take the back cover out.
      Ask FixBot
    3. Samsung NP350V5C-T02US RAM Replacement: step 3, image 1 of 1
      • Using your hand slide the ODD/HDD/Memory panel off in a downward motion.
      Ask FixBot
    1. Samsung NP350V5C-T02US RAM Replacement, RAM: step 4, image 1 of 1
      • Locate the RAM in the lower right hand corner.
      Ask FixBot
    2. Samsung NP350V5C-T02US RAM Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Depress both sides of the lock mechanism at the same time using tweezers to remove the RAM.
      • Since there are two RAMs, remove the other one by using the same method.
      Ask FixBot
    3. Samsung NP350V5C-T02US RAM Replacement: step 6, image 1 of 1
      • After removing all RAMs, the empty space looks like this. Then users can install the new RAMs.
      Ask FixBot
1 Guide Comment
Hello,
Thank you for all of the guides. I was curious if you know what the maximum amount of RAM that this laptop can be upgraded to?
On the Samsung site, it says the max is 8 GB, however the Intel site says 32 GB is the max for the processor.
Could the difference be the motherboard?
Thanks!
Will
Will Terfansky - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 101
All Time: 1,664
