Samsung NP305E5A-A03US RAM Replacement
    1. Samsung NP305E5A-A03US RAM Replacement, Hard Drive: step 1, image 1 of 1
      • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
      Ask FixBot
    2. Samsung NP305E5A-A03US RAM Replacement: step 2, image 1 of 1
      • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
      • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
      Ask FixBot
    3. Samsung NP305E5A-A03US RAM Replacement: step 3, image 1 of 2 Samsung NP305E5A-A03US RAM Replacement: step 3, image 2 of 2
      • Pull the panel towards you to remove the panel.
      Ask FixBot
    4. Samsung NP305E5A-A03US RAM Replacement: step 4, image 1 of 1
      • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
      • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
      Ask FixBot
    5. Samsung NP305E5A-A03US RAM Replacement: step 5, image 1 of 2 Samsung NP305E5A-A03US RAM Replacement: step 5, image 2 of 2
      • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
      Ask FixBot
    6. Samsung NP305E5A-A03US RAM Replacement: step 6, image 1 of 1
      • Remove the Hard Drive by lifting it towards you.
      Ask FixBot
    1. Samsung NP305E5A-A03US RAM Replacement, RAM: step 7, image 1 of 1
      • Place your thumbs on the metal tabs.
      • Push outwards on the metal tabs to release the RAM.
      Ask FixBot
    2. Samsung NP305E5A-A03US RAM Replacement: step 8, image 1 of 2 Samsung NP305E5A-A03US RAM Replacement: step 8, image 2 of 2
      • Pull out the RAM towards you to remove it from the laptop.
      Ask FixBot
2 other people completed this guide.
Julia Dotter
236 Reputation
1 Guide authored
Baylor, Team 5-7, Williams Fall 2016 Member of Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 113
All Time: 951
