Samsung NP300E5C Screen Replacement
    1. Samsung NP300E5C Screen Replacement, Battery: step 1, image 1 of 1
      • Lay laptop down so that the bottom is facing the sky.
      Ask FixBot
    2. Samsung NP300E5C Screen Replacement: step 2, image 1 of 3 Samsung NP300E5C Screen Replacement: step 2, image 2 of 3 Samsung NP300E5C Screen Replacement: step 2, image 3 of 3
      • Push both tabs away from the center of the device.
      • While both are in the fully unlocked position, slide the battery out.
      Ask FixBot
    1. Samsung NP300E5C Screen Replacement, Screen: step 3, image 1 of 1
      • Turn the laptop over and open it so that you can see the keyboard and screen.
      • Using a Phillips #000 screwdriver, remove the two 4 mm Phillips #8 screws that are under the black covers on the front of your screen.
      • You can remove the black covers by simply pushing your screwdriver into them.
      Ask FixBot
    2. Samsung NP300E5C Screen Replacement: step 4, image 1 of 3 Samsung NP300E5C Screen Replacement: step 4, image 2 of 3 Samsung NP300E5C Screen Replacement: step 4, image 3 of 3
      • Insert the plastic opening tool into the seam on the top of the screen.
      • The seam is where the back screen cover and the plastic bezel around the edges of the screen meet.
      • Use the plastic opening tool to pop open the clasps that keep the casing on the screen.
      • It helps to use the plastic opening tool like a crowbar.
      • Follow this seam around the laptop's screen with the plastic opening tool until the plastic cover comes off.
      • Don't be afraid to use your fingers to help pop open the clips.
      Ask FixBot
    3. Samsung NP300E5C Screen Replacement: step 5, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the top two 4 mm Phillips #8 screws that join the LCD screen to the plastic casing.
      • Using the same screwdriver, remove the bottom four 4 mm Phillips #8 screws that mount the screen onto the base of the laptop.
      • As you remove these bottom 4 screws, support the screen! As the screws come off, the screen will begin to fall backwards.
      Ask FixBot
    4. Samsung NP300E5C Screen Replacement: step 6, image 1 of 3 Samsung NP300E5C Screen Replacement: step 6, image 2 of 3 Samsung NP300E5C Screen Replacement: step 6, image 3 of 3
      • Gently lay the LCD on the keyboard, and lay down the back panel of the screen as well. They are not attached and will separate easily.
      • The LCD and the back panel must remain close to one another due to the video connector at the bottom that links the two.
      • Remove the tape that secures the video connector to the LCD.
      • While maintaining a firm grip on the LCD, grasp the video connector at its base, and pull it away from you.
      • Don't be afraid to pull, the video connector is not soldered onto the LCD.
      Ask FixBot
10 other people completed this guide.
aliahsan95
937 Reputation
4 Guides authored
Baylor, Team 10-13, Williams Fall 2015 Member of Baylor, Team 10-13, Williams Fall 2015
BU-WILLIAMS-F15S10G13
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 131
All Time: 7,011
