Samsung NP300E5C Optical Drive Replacement
    1. Samsung NP300E5C Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Lay laptop down so that the bottom is facing the sky.
      Ask FixBot
    2. Samsung NP300E5C Optical Drive Replacement: step 2, image 1 of 3 Samsung NP300E5C Optical Drive Replacement: step 2, image 2 of 3 Samsung NP300E5C Optical Drive Replacement: step 2, image 3 of 3
      • Push both tabs away from the center of the device.
      • While both are in the fully unlocked position, slide the battery out.
      Ask FixBot
    1. Samsung NP300E5C Optical Drive Replacement, Optical Drive: step 3, image 1 of 1
      • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung NP300E5C Optical Drive Replacement: step 4, image 1 of 2 Samsung NP300E5C Optical Drive Replacement: step 4, image 2 of 2
      • With the 4 mm Phillips #8 screw removed, firmly but gently pull the cover towards you.
      • After moving the cover about 2 centimeters, you can lift and remove it.
      Ask FixBot
    3. Samsung NP300E5C Optical Drive Replacement: step 5, image 1 of 1
      • Remove the 4 mm Phillips #8 screw to the left of the hard drive using a Phillips #00 screwdriver.
      Ask FixBot
    4. Samsung NP300E5C Optical Drive Replacement: step 6, image 1 of 2 Samsung NP300E5C Optical Drive Replacement: step 6, image 2 of 2
      • Using your fingernail or spudger to gently pull your optical drive out.
      Ask FixBot
3 other people completed this guide.
aliahsan95
937 Reputation
4 Guides authored
Baylor, Team 10-13, Williams Fall 2015 Member of Baylor, Team 10-13, Williams Fall 2015
BU-WILLIAMS-F15S10G13
3 Members
48 Guides authored
1 Guide Comment
Great video, simple steps to follow, very good, thanks.
Chris Hughes - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 103
All Time: 3,190
