Samsung NP300E5C Hard Drive Replacement
    1. Samsung NP300E5C Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Lay laptop down so that the bottom is facing the sky.
      Ask FixBot
    2. Samsung NP300E5C Hard Drive Replacement: step 2, image 1 of 3 Samsung NP300E5C Hard Drive Replacement: step 2, image 2 of 3 Samsung NP300E5C Hard Drive Replacement: step 2, image 3 of 3
      • Push both tabs away from the center of the device.
      • While both are in the fully unlocked position, slide the battery out.
      Ask FixBot
    1. Samsung NP300E5C Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
      • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
      • Firmly, but gently pull the cover towards you.
      • After moving the cover about 2 centimeters, you can lift and remove it.
      Ask FixBot
    2. Samsung NP300E5C Hard Drive Replacement: step 4, image 1 of 3 Samsung NP300E5C Hard Drive Replacement: step 4, image 2 of 3 Samsung NP300E5C Hard Drive Replacement: step 4, image 3 of 3
      • Remove these four 4 mm Phillips #8 screws using a Phillips #00 screwdriver.
      • Gently lift the hard drive up, however do not remove it.
      Ask FixBot
    3. Samsung NP300E5C Hard Drive Replacement: step 5, image 1 of 2 Samsung NP300E5C Hard Drive Replacement: step 5, image 2 of 2
      • Firmly grasp the base of the connector at the bottom of the hard drive.
      • Gently pull the connector off to free the hard drive.
      Ask FixBot
11 other people completed this guide.
aliahsan95
937 Reputation
4 Guides authored
Baylor, Team 10-13, Williams Fall 2015 Member of Baylor, Team 10-13, Williams Fall 2015
BU-WILLIAMS-F15S10G13
3 Members
48 Guides authored
2 Guide Comments
I want to change this HDD with a SSD drive. How do I know which drive to look for? Do i need some kind of adapter or i just have to plug it?
johnetix - Reply Share
The HDD is connected using Serial ATA (SATA) and most modern SSD drives will also use a SATA connection. You will be able to install the new drive without any adapters.
Oscar B - Reply Share
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 129
All Time: 14,002
