Samsung NP270E5E-K03US RAM Replacement
    1. Samsung NP270E5E-K03US RAM Replacement, Battery: step 1, image 1 of 2 Samsung NP270E5E-K03US RAM Replacement, Battery: step 1, image 2 of 2
      • Begin with the laptop lying to its back revealing its underside.
      • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
      Ask FixBot
    2. Samsung NP270E5E-K03US RAM Replacement: step 2, image 1 of 2 Samsung NP270E5E-K03US RAM Replacement: step 2, image 2 of 2
      • Completely remove the battery from the laptop.
      Ask FixBot
    1. Samsung NP270E5E-K03US RAM Replacement, RAM: step 3, image 1 of 1
      • Remove the 4mm screw with a Phillips #0 screwdriver.
      Ask FixBot
    2. Samsung NP270E5E-K03US RAM Replacement: step 4, image 1 of 3 Samsung NP270E5E-K03US RAM Replacement: step 4, image 2 of 3 Samsung NP270E5E-K03US RAM Replacement: step 4, image 3 of 3
      • Once the screw holding the cover down has been removed the cover can then be removed by sliding the cover in the direction of the gray arrow on the laptop.
      • The cover can then be removed to reveal the laptops RAM boards and also the laptops hard drive.
      Ask FixBot
    3. Samsung NP270E5E-K03US RAM Replacement: step 5, image 1 of 3 Samsung NP270E5E-K03US RAM Replacement: step 5, image 2 of 3 Samsung NP270E5E-K03US RAM Replacement: step 5, image 3 of 3
      • The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
      • To disengage the latches you must push them gently outwards until a soft click is heard.
      • If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
      Ask FixBot
    4. Samsung NP270E5E-K03US RAM Replacement: step 6, image 1 of 1
      • You can now pull the RAM board from the housing freeing up space for your new replacement RAM board.
      • Do not try to remove the RAM before the latches have disengaged and the RAM has popped up, otherwise risk damaging the computer / components.
      Ask FixBot
Kyle Golden
353 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 116
All Time: 1,862
