Up to 20% off select tools
Samsung NP-R540-JA09US Hard Drive Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
77
All Time:
1,680
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Is your computer not loading filed properly or are you out of storage? Consider using this guide to replace the hard drive in your laptop.
    1. Samsung NP-R540-JA09US Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Samsung NP-R540-JA09US Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • Flip the device to the bottoms-up position and locate the panel that says HDD.
      • In case of damage to panel, the HDD panel is just immediately right of the optical drive, and opposite from the battery
      Ask FixBot
    2. Samsung NP-R540-JA09US Hard Drive Replacement: step 2, image 1 of 3 Samsung NP-R540-JA09US Hard Drive Replacement: step 2, image 2 of 3 Samsung NP-R540-JA09US Hard Drive Replacement: step 2, image 3 of 3
      • Remove the two 3.7mm securing screws with a Phillips #0 screwdriver.
      • After removing the screws, remove the panel covering the HDD.
      Ask FixBot
    3. Samsung NP-R540-JA09US Hard Drive Replacement: step 3, image 1 of 3 Samsung NP-R540-JA09US Hard Drive Replacement: step 3, image 2 of 3 Samsung NP-R540-JA09US Hard Drive Replacement: step 3, image 3 of 3
      • Remove the screws on the bracket and then remove the bracket by pulling up.
      • Once the bracket has been removed, slide the hard drive towards the gap in the cavity and then remove it from the device.
      Ask FixBot
2 other people completed this guide.
Author
with
Conner Patterson
381 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 77
All Time: 1,680
