Samsung NP-QX411L Screen Replacement
    1. Samsung NP-QX411L Screen Replacement, Optical Drive: step 1, image 1 of 2 Samsung NP-QX411L Screen Replacement, Optical Drive: step 1, image 2 of 2
      • Flip the laptop over.
      • Remove the 6 mm screw with the Phillips #000 screwdriver.
      Ask FixBot
    2. Samsung NP-QX411L Screen Replacement: step 2, image 1 of 1
      • Slide out the optical drive to remove it.
      Ask FixBot
    1. Samsung NP-QX411L Screen Replacement, Hard Drive: step 3, image 1 of 2 Samsung NP-QX411L Screen Replacement, Hard Drive: step 3, image 2 of 2
      • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
      • Flip the laptop.
      • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
      Ask FixBot
    2. Samsung NP-QX411L Screen Replacement: step 4, image 1 of 2 Samsung NP-QX411L Screen Replacement: step 4, image 2 of 2
      • Gently wedge the spudger under the square panel.
      • Run the spudger under the edges of the square panel to loosen it.
      • Remove the panel.
      Ask FixBot
    3. Samsung NP-QX411L Screen Replacement: step 5, image 1 of 1
      • Remove the hard drive slowly because it is still connected to a wire.
      • Pull up on the rubber flap or use the spudger to lift the hard drive.
      Ask FixBot
    4. Samsung NP-QX411L Screen Replacement: step 6, image 1 of 1
      • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
      Ask FixBot
    1. Samsung NP-QX411L Screen Replacement, Hinges: step 7, image 1 of 2 Samsung NP-QX411L Screen Replacement, Hinges: step 7, image 2 of 2
      • Disconnect the wire from the motherboard by pulling up and away from the laptop.
      Ask FixBot
    2. Samsung NP-QX411L Screen Replacement: step 8, image 1 of 2 Samsung NP-QX411L Screen Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the top two rubber stoppers using precision tweezers.
      Ask FixBot
    3. Samsung NP-QX411L Screen Replacement: step 9, image 1 of 1
      • Unscrew nine 6 mm screws on the cover using a Phillips #000 screwdriver.
      Ask FixBot
    4. Samsung NP-QX411L Screen Replacement: step 10, image 1 of 3 Samsung NP-QX411L Screen Replacement: step 10, image 2 of 3 Samsung NP-QX411L Screen Replacement: step 10, image 3 of 3
      • Wedge the spudger under the cover to gently pry it up.
      Ask FixBot
    5. Samsung NP-QX411L Screen Replacement: step 11, image 1 of 3 Samsung NP-QX411L Screen Replacement: step 11, image 2 of 3 Samsung NP-QX411L Screen Replacement: step 11, image 3 of 3
      • Disconnect the wire by carefully using the plastic opening tool to pry the connector away from the motherboard.
      Ask FixBot
    6. Samsung NP-QX411L Screen Replacement: step 12, image 1 of 3 Samsung NP-QX411L Screen Replacement: step 12, image 2 of 3 Samsung NP-QX411L Screen Replacement: step 12, image 3 of 3
      • Use precision tweezers to pop the antenna wires off of the WiFi card.
      Ask FixBot
    7. Samsung NP-QX411L Screen Replacement: step 13, image 1 of 3 Samsung NP-QX411L Screen Replacement: step 13, image 2 of 3 Samsung NP-QX411L Screen Replacement: step 13, image 3 of 3
      • Open the laptop slightly.
      • Holding the laptop open, remove three 4 mm screws from each hinge (6 total) using a Phillips #000 screwdriver.
      Ask FixBot
    8. Samsung NP-QX411L Screen Replacement: step 14, image 1 of 1
      • Hold hinges in place with your thumb and slide the laptop away from the screen.
      Ask FixBot
    9. Samsung NP-QX411L Screen Replacement: step 15, image 1 of 2 Samsung NP-QX411L Screen Replacement: step 15, image 2 of 2
      • Remove the 4 rubber stoppers with the precision tweezers.
      Ask FixBot
    10. Samsung NP-QX411L Screen Replacement: step 16, image 1 of 2 Samsung NP-QX411L Screen Replacement: step 16, image 2 of 2
      • Remove the four 4 mm screws with a Phillips #000 screwdriver.
      Ask FixBot
    11. Samsung NP-QX411L Screen Replacement: step 17, image 1 of 2 Samsung NP-QX411L Screen Replacement: step 17, image 2 of 2
      • The metal spudger could scratch the screen.
      • Wedge the metal spudger underneath the cover and run it along the edges. Gently pry the cover up.
      Ask FixBot
    12. Samsung NP-QX411L Screen Replacement: step 18, image 1 of 2 Samsung NP-QX411L Screen Replacement: step 18, image 2 of 2
      • Remove the three 4 mm screws on each hinge with a Phillips #000 screwdriver. There should be a total of 6 screws to remove.
      Ask FixBot
    1. Samsung NP-QX411L Screen Replacement, Screen: step 19, image 1 of 2 Samsung NP-QX411L Screen Replacement, Screen: step 19, image 2 of 2
      • Remove the four 4 mm screws using Phillips #000 screwdriver.
      • Remove metal brackets.
      Ask FixBot
    2. Samsung NP-QX411L Screen Replacement: step 20, image 1 of 1
      • Use the small suction cup to lift the screen.
      • Disconnect the wire by pulling it away from the bottom of the screen.
      Ask FixBot
Rebecca Johnson
594 Reputation
5 Guides authored
USF Tampa, Team S19-G3, Hoffman Spring 2017 Member of USF Tampa, Team S19-G3, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 96
All Time: 1,602
