Samsung NP-QX411L Hard Drive Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
97
All Time:
2,083
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If you want to replace your hard drive for problems such as being unable to access files, this guide walks you through lifting the cover and removing the hard drive. The steps should be easy to follow. Just make sure to wear an anti-static wristband to avoid shocking the motherboard.
Tools
    1. Samsung NP-QX411L Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Samsung NP-QX411L Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
      • Flip the laptop.
      • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
      Ask FixBot
    2. Samsung NP-QX411L Hard Drive Replacement: step 2, image 1 of 2 Samsung NP-QX411L Hard Drive Replacement: step 2, image 2 of 2
      • Gently wedge the spudger under the square panel.
      • Run the spudger under the edges of the square panel to loosen it.
      • Remove the panel.
      Ask FixBot
    3. Samsung NP-QX411L Hard Drive Replacement: step 3, image 1 of 1
      • Remove the hard drive slowly because it is still connected to a wire.
      • Pull up on the rubber flap or use the spudger to lift the hard drive.
      Ask FixBot
    4. Samsung NP-QX411L Hard Drive Replacement: step 4, image 1 of 1
      • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
      Ask FixBot
2 other people completed this guide.
Rebecca Johnson
594 Reputation
5 Guides authored
USF Tampa, Team S19-G3, Hoffman Spring 2017 Member of USF Tampa, Team S19-G3, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 97
All Time: 2,083
