Samsung NP-QX411L Battery Replacement
    1. Samsung NP-QX411L Battery Replacement, Optical Drive: step 1, image 1 of 2 Samsung NP-QX411L Battery Replacement, Optical Drive: step 1, image 2 of 2
      • Flip the laptop over.
      • Remove the 6 mm screw with the Phillips #000 screwdriver.
      Ask FixBot
    2. Samsung NP-QX411L Battery Replacement: step 2, image 1 of 1
      • Slide out the optical drive to remove it.
      Ask FixBot
    1. Samsung NP-QX411L Battery Replacement, Hard Drive: step 3, image 1 of 2 Samsung NP-QX411L Battery Replacement, Hard Drive: step 3, image 2 of 2
      • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
      • Flip the laptop.
      • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
      Ask FixBot
    2. Samsung NP-QX411L Battery Replacement: step 4, image 1 of 2 Samsung NP-QX411L Battery Replacement: step 4, image 2 of 2
      • Gently wedge the spudger under the square panel.
      • Run the spudger under the edges of the square panel to loosen it.
      • Remove the panel.
      Ask FixBot
    3. Samsung NP-QX411L Battery Replacement: step 5, image 1 of 1
      • Remove the hard drive slowly because it is still connected to a wire.
      • Pull up on the rubber flap or use the spudger to lift the hard drive.
      Ask FixBot
    4. Samsung NP-QX411L Battery Replacement: step 6, image 1 of 1
      • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
      Ask FixBot
    1. Samsung NP-QX411L Battery Replacement, Battery: step 7, image 1 of 1
      • Use the Phillips #000 screwdriver to remove the 6 mm screw.
      Ask FixBot
    2. Samsung NP-QX411L Battery Replacement: step 8, image 1 of 2 Samsung NP-QX411L Battery Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the top two rubber stoppers by grasping them with the precision tweezers and pulling up.
      Ask FixBot
    3. Samsung NP-QX411L Battery Replacement: step 9, image 1 of 1
      • Remove nine 6mm cover screws using the Phillips #000 screwdriver.
      Ask FixBot
    4. Samsung NP-QX411L Battery Replacement: step 10, image 1 of 3 Samsung NP-QX411L Battery Replacement: step 10, image 2 of 3 Samsung NP-QX411L Battery Replacement: step 10, image 3 of 3
      • Wedge the spudger under the cover and run it along the edges.
      • Pry the cover up with the spudger to remove it.
      Ask FixBot
    5. Samsung NP-QX411L Battery Replacement: step 11, image 1 of 2 Samsung NP-QX411L Battery Replacement: step 11, image 2 of 2
      • Remove the four 3 mm screws using the Phillips #000 screwdriver.
      Ask FixBot
    6. Samsung NP-QX411L Battery Replacement: step 12, image 1 of 1
      • A wire is still connecting the battery to the motherboard.
      • Lift and slide the battery out from under the three plastic prongs.
      Ask FixBot
    7. Samsung NP-QX411L Battery Replacement: step 13, image 1 of 1
      • Grab the wires and gently pull them away from the motherboard.
      Ask FixBot
3 other people completed this guide.
Rebecca Johnson
594 Reputation
5 Guides authored
USF Tampa, Team S19-G3, Hoffman Spring 2017 Member of USF Tampa, Team S19-G3, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G3
4 Members
60 Guides authored
1 Guide Comment
Pardon the interruption, but do you potentially have a tutorial on how to replace the keyboard on this laptop? I am having problems finding an acceptable-enough tutorial on how to do it, yet I need such a tutorial as the process seems quite daunting.
Thanks,
Random Person on the Internet
Anonymous Schmuck - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 128
All Time: 4,746
