Samsung NP-N210-JA02US Hard Drive Replacement
    1. Samsung NP-N210-JA02US Hard Drive Replacement, Battery: step 1, image 1 of 2 Samsung NP-N210-JA02US Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Carefully slide both locking pins to the unlocked position.
      Ask FixBot
    2. Samsung NP-N210-JA02US Hard Drive Replacement: step 2, image 1 of 1
      • Slide the battery out of its housing.
      Ask FixBot
    1. Samsung NP-N210-JA02US Hard Drive Replacement, Hard Drive Removal: step 3, image 1 of 1
      • Remove the following 14 screws:
      • Thirteen 5 mm Phillips #1 screws
      • One 3.5 mm Philips #001 screw
      Ask FixBot
    2. Samsung NP-N210-JA02US Hard Drive Replacement: step 4, image 1 of 1
      • Carefully insert the plastic opening tool into the seam between the lower casing and the chrome bezel.
      Ask FixBot
    3. Samsung NP-N210-JA02US Hard Drive Replacement: step 5, image 1 of 1
      • Slide the opening tool across all sides of the lower case. Then, lift it up to remove the case and reveal the internal components.
      Ask FixBot
    4. Samsung NP-N210-JA02US Hard Drive Replacement: step 6, image 1 of 3 Samsung NP-N210-JA02US Hard Drive Replacement: step 6, image 2 of 3 Samsung NP-N210-JA02US Hard Drive Replacement: step 6, image 3 of 3
      • Carefully unplug the SATA connector from the hard drive.
      Ask FixBot
    5. Samsung NP-N210-JA02US Hard Drive Replacement: step 7, image 1 of 2 Samsung NP-N210-JA02US Hard Drive Replacement: step 7, image 2 of 2
      • Remove the four black 3.5 mm Philips #1 screws on the (side) of the hard drive.
      Ask FixBot
    6. Samsung NP-N210-JA02US Hard Drive Replacement: step 8, image 1 of 1
      • Gently lift the hard drive from its mounting bracket.
      Ask FixBot
11 other people completed this guide.
Afif Chehabaldeen
401 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 42
All Time: 4,353
