Samsung NP-N145-JP02US Screen Replacement
    1. Samsung NP-N145-JP02US Screen Replacement, Screen: step 1, image 1 of 1
      • Before starting replacement, turn off the device and disconnect all cords.
      • Close the device, lay it face down, and remove the battery.
      Ask FixBot
    2. Samsung NP-N145-JP02US Screen Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the four black screw covers located at all corners of the screen with tweezers to expose the screws
      • Remove the four 4.5 mm screws located at each corner of the screen by using the Phillips #0 screwdriver.
      Ask FixBot
    3. Samsung NP-N145-JP02US Screen Replacement: step 3, image 1 of 1
      • Use a blue prying tool to pry the screen frame off.
      • Unscrew the four 6.5mm screws that are securing the screen using Phillips J0 screwdriver head.
      Ask FixBot
    4. Samsung NP-N145-JP02US Screen Replacement: step 4, image 1 of 3 Samsung NP-N145-JP02US Screen Replacement: step 4, image 2 of 3 Samsung NP-N145-JP02US Screen Replacement: step 4, image 3 of 3
      • Using your fingertips, gently pull screen to pop it out of the frame.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 113
All Time: 1,036
