Samsung NP-N145-JP02US Fan Replacement
    1. Samsung NP-N145-JP02US Fan Replacement, Fan: step 1, image 1 of 1
      • Before starting the replacement, turn off the device sure and disconnect all cords.
      • Close the device, lay it face down, and remove the battery.
      Ask FixBot
    2. Samsung NP-N145-JP02US Fan Replacement: step 2, image 1 of 1
      • Remove the back of the device from the main frame by unscrewing the 14 4.5 mm screws using a Phillips #0 screwdriver.
      • Once all screws are out, pry open the back cover piece of the device using a plastic opening tool.
      Ask FixBot
    3. Samsung NP-N145-JP02US Fan Replacement: step 3, image 1 of 1
      • Remove the four 6.5 mm screws that surround the fan using the PH1 Phillips screwdriver head.
      Ask FixBot
    4. Samsung NP-N145-JP02US Fan Replacement: step 4, image 1 of 1
      • Manually remove the fan from the device by pulling out the connector.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 41
All Time: 1,106
