Samsung NP-N102S-B05PH RAM Replacement
    1. Samsung NP-N102S-B05PH RAM Replacement, RAM: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver, take out the 4.6mm screw holding the RAM slot down.
      Ask FixBot
    2. Samsung NP-N102S-B05PH RAM Replacement: step 2, image 1 of 2 Samsung NP-N102S-B05PH RAM Replacement: step 2, image 2 of 2
      • Insert the flat end of the black spudger into the small notch in the RAM slot and lift the top off.
      Ask FixBot
    3. Samsung NP-N102S-B05PH RAM Replacement: step 3, image 1 of 2 Samsung NP-N102S-B05PH RAM Replacement: step 3, image 2 of 2
      • Now that the RAM chip has been exposed, use your fingertip and the black spudger to push back the metal tabs on each side, allowing the RAM chip to come free.
      Ask FixBot
    4. Samsung NP-N102S-B05PH RAM Replacement: step 4, image 1 of 2 Samsung NP-N102S-B05PH RAM Replacement: step 4, image 2 of 2
      • Finally, use the black spudger to get underneath the loosened RAM chip and gently pull it up and out of the laptop.
      Ask FixBot
Daniel Rudzik
349 Reputation
3 Guides authored
USF Tampa, Team 2-4, Nance Fall 2016 Member of USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 100
All Time: 893
