Samsung NP-130-JA01US RAM Replacement
    1. Samsung NP-130-JA01US RAM Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charger cable from the computer.
      • Failure to disconnect the charger cable from the computer could result in an electric shock.
      • Flip the computer over so the underside is facing up.
      Ask FixBot
    2. Samsung NP-130-JA01US RAM Replacement: step 2, image 1 of 2 Samsung NP-130-JA01US RAM Replacement: step 2, image 2 of 2
      • Slide the left and right slider buttons fully away from each other.
      Ask FixBot
    3. Samsung NP-130-JA01US RAM Replacement: step 3, image 1 of 1
      • Pull the battery out of the computer.
      Ask FixBot
    1. Samsung NP-130-JA01US RAM Replacement, RAM: step 4, image 1 of 2 Samsung NP-130-JA01US RAM Replacement, RAM: step 4, image 2 of 2
      • Locate the "Memory" panel on the bottom right corner.
      • Use the Phillips 01 screwdriver to remove the screw.
      • The screw is a Phillips 1 (PH 1) with a length of 60 millimeters (mm)
      Ask FixBot
    2. Samsung NP-130-JA01US RAM Replacement: step 5, image 1 of 1
      • With your hand, lift panel and remove it.
      Ask FixBot
    3. Samsung NP-130-JA01US RAM Replacement: step 6, image 1 of 2 Samsung NP-130-JA01US RAM Replacement: step 6, image 2 of 2
      • Slide metal prongs (marked in red squares) away from each other with your fingers.
      • The RAM chip will automatically lift up at an angle for easy ejection.
      Ask FixBot
    4. Samsung NP-130-JA01US RAM Replacement: step 7, image 1 of 1
      • With your hands, carefully slide the RAM chip out to remove.
      • The RAM chip is delicate, do not force it when removing it.
      Ask FixBot
Jason Schnebelen
267 Reputation
2 Guides authored
USF Tampa, Team 9-6, Lacy Fall 2016 Member of USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 106
All Time: 686
