Samsung NP-130-JA01US Keyboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
105
All Time:
846
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
An unresponsive keyboard is a common problem with computers. When problems arise you will need to either replace the keyboard, or attempt to fix the hardware. Either way, the keyboard must be removed from the device.
Tools
    1. Samsung NP-130-JA01US Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charger cable from the computer.
      • Failure to disconnect the charger cable from the computer could result in an electric shock.
      • Flip the computer over so the underside is facing up.
      Ask FixBot
    2. Samsung NP-130-JA01US Keyboard Replacement: step 2, image 1 of 2 Samsung NP-130-JA01US Keyboard Replacement: step 2, image 2 of 2
      • Slide the left and right slider buttons fully away from each other.
      Ask FixBot
    3. Samsung NP-130-JA01US Keyboard Replacement: step 3, image 1 of 1
      • Pull the battery out of the computer.
      Ask FixBot
    1. Samsung NP-130-JA01US Keyboard Replacement, Keyboard: step 4, image 1 of 2 Samsung NP-130-JA01US Keyboard Replacement, Keyboard: step 4, image 2 of 2
      • Using a Phillips 1 screwdriver carefully remove all 12 screws of the back cover.
      • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
      • Do not force the screwdriver as you might damage the screws.
      Ask FixBot
    2. Samsung NP-130-JA01US Keyboard Replacement: step 5, image 1 of 3 Samsung NP-130-JA01US Keyboard Replacement: step 5, image 2 of 3 Samsung NP-130-JA01US Keyboard Replacement: step 5, image 3 of 3
      • Flip the computer and open the front cover so that the screen is looking at you.
      • Using a Metal Spudger and your dominant hand, carefully separate the keyboard from the computer frame.
      • Do not force the keyboard out, it should come out easily with the help of the Metal Spudger
      Ask FixBot
    3. Samsung NP-130-JA01US Keyboard Replacement: step 6, image 1 of 3 Samsung NP-130-JA01US Keyboard Replacement: step 6, image 2 of 3 Samsung NP-130-JA01US Keyboard Replacement: step 6, image 3 of 3
      • Flip the keyboard over.
      • Notice the lock mechanism (marked in red) that holds the cables to the computer.
      • With your fingers, flip the mechanism over before pulling the cables out.
      • Second picture shows the unlocked position.
      • Carefully pull the cables out of the computer.
      Ask FixBot
Alejandro Guerra Piol
335 Reputation
2 Guides authored
USF Tampa, Team 9-6, Lacy Fall 2016 Member of USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 105
All Time: 846
