Samsung NP-130-JA01US Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
94
All Time:
763
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
An overheating laptop is a common problem when the internal fan of the computer is either blocked or not working properly.
Excessive heat in your computer will cause it to turn off, and might lead to performance problems in the future. Cleaning or replacing the fan is a cheap way of solving the problem.
Tools
    1. Samsung NP-130-JA01US Fan Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charger cable from the computer.
      • Failure to disconnect the charger cable from the computer could result in an electric shock.
      • Flip the computer over so the underside is facing up.
      Ask FixBot
    2. Samsung NP-130-JA01US Fan Replacement: step 2, image 1 of 2 Samsung NP-130-JA01US Fan Replacement: step 2, image 2 of 2
      • Slide the left and right slider buttons fully away from each other.
      Ask FixBot
    3. Samsung NP-130-JA01US Fan Replacement: step 3, image 1 of 1
      • Pull the battery out of the computer.
      Ask FixBot
    1. Samsung NP-130-JA01US Fan Replacement, Fan: step 4, image 1 of 2 Samsung NP-130-JA01US Fan Replacement, Fan: step 4, image 2 of 2
      • Using a Phillips 1 screwdriver, carefully remove all 12 screws of the back cover.
      • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
      • Do not force the screwdriver as you might damage the screws.
      Ask FixBot
    2. Samsung NP-130-JA01US Fan Replacement: step 5, image 1 of 3 Samsung NP-130-JA01US Fan Replacement: step 5, image 2 of 3 Samsung NP-130-JA01US Fan Replacement: step 5, image 3 of 3
      • With the plastic opening tool, carefully separate the back cover from the computer frame.
      • Starting at one of the corners of the computer, work your way around the edge until you reach the other corner.
      • Do not attempt to pry it open, putting too much force into one location might damage the computer.
      • As you go around the sides of the computer, free the inside latches with the plastic opening tool.
      • Once you have an opening, carefully use your hands to separate the back cover.
      Ask FixBot
    3. Samsung NP-130-JA01US Fan Replacement: step 6, image 1 of 2 Samsung NP-130-JA01US Fan Replacement: step 6, image 2 of 2
      • Locate the fan (marked in a red square).
      Ask FixBot
    4. Samsung NP-130-JA01US Fan Replacement: step 7, image 1 of 3 Samsung NP-130-JA01US Fan Replacement: step 7, image 2 of 3 Samsung NP-130-JA01US Fan Replacement: step 7, image 3 of 3
      • Using a Phillips 1 screwdriver, remove the screw marked in a red circle.
      • The screw is a Phillips 1 (PH 1) with a length of 40 millimeters (mm)
      • Do not use too much force on the screw driver, you might damage the screw.
      • Using your hands, carefully unplug the cords marked in a green square.
      Ask FixBot
    5. Samsung NP-130-JA01US Fan Replacement: step 8, image 1 of 2 Samsung NP-130-JA01US Fan Replacement: step 8, image 2 of 2
      • Carefully remove the fan.
      Ask FixBot
Alejandro Guerra Piol
335 Reputation
2 Guides authored
USF Tampa, Team 9-6, Lacy Fall 2016 Member of USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 94
All Time: 763
