Up to 20% off select tools
Samsung N150 Plus RAM Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
124
All Time:
2,719
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide will allow the user to install a 2GB RAM to increase the laptops ability to run multiple programs and will improve overall efficiency.
    1. Samsung N150 Plus RAM Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charging cable from the laptop.
      • Failure to unplug the cable could result in electric shock.
      • Flip the laptop upside down with the front face down on a flat surface.
      Ask FixBot
    2. Samsung N150 Plus RAM Replacement: step 2, image 1 of 2 Samsung N150 Plus RAM Replacement: step 2, image 2 of 2
      • Slide the left and right switch to the "unlocked" position.
      Ask FixBot
    3. Samsung N150 Plus RAM Replacement: step 3, image 1 of 2 Samsung N150 Plus RAM Replacement: step 3, image 2 of 2
      • While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
      Ask FixBot
    1. Samsung N150 Plus RAM Replacement, Back Panel: step 4, image 1 of 1
      • Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
      Ask FixBot
    2. Samsung N150 Plus RAM Replacement: step 5, image 1 of 1
      • Using either the blue plastic opening tools or spudger tool, wedge one in between the back panel and the laptop.
      • Apply pressure upwards till the back panel pops off.
      • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
      Ask FixBot
    3. Samsung N150 Plus RAM Replacement: step 6, image 1 of 2 Samsung N150 Plus RAM Replacement: step 6, image 2 of 2
      • The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard.
      Ask FixBot
    1. Samsung N150 Plus RAM Replacement, RAM: step 7, image 1 of 2 Samsung N150 Plus RAM Replacement, RAM: step 7, image 2 of 2
      • Using your hands, push the two metal clip holders on each side away from the RAM till you hear a clicking sound.
      • If you push the metal rods away from the RAM as directed, the RAM will pop up at an angle.
      Ask FixBot
    2. Samsung N150 Plus RAM Replacement: step 8, image 1 of 1
      • Gently pull out the stick of RAM.
      Ask FixBot
Author
with
patrick Russell
830 Reputation
6 Guides authored
1 Guide Comment
There is no need to open the entire casing. There is a special lid on the back that covers the SODIMM for easy access. It can be replaced removing only one screw.
Fred - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 124
All Time: 2,719
