Up to 20% off select tools
Samsung N150 Plus Battery Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
109
All Time:
3,053
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 seconds - 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
We are going to teach someone how to remove the battery in four easy steps. This is the first necessary step that will allow you to remove the back panel to replace other internal components.
    1. Samsung N150 Plus Battery Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charging cable from the laptop.
      • Failure to unplug the cable could result in electric shock.
      • Flip the laptop upside down with the front face down on a flat surface.
      Ask FixBot
    2. Samsung N150 Plus Battery Replacement: step 2, image 1 of 2 Samsung N150 Plus Battery Replacement: step 2, image 2 of 2
      • Slide the left and right switch to the "unlocked" position.
      Ask FixBot
    3. Samsung N150 Plus Battery Replacement: step 3, image 1 of 2 Samsung N150 Plus Battery Replacement: step 3, image 2 of 2
      • While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
      Ask FixBot
Author
with
patrick Russell
830 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 109
All Time: 3,053
