Samsung Mythic SGH-a897 LCD Replacement
    1. Samsung Mythic SGH-a897 LCD Replacement, Battery: step 1, image 1 of 1
      • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
      Ask FixBot
    2. Samsung Mythic SGH-a897 LCD Replacement: step 2, image 1 of 1
      • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
      Ask FixBot
    1. Samsung Mythic SGH-a897 LCD Replacement, Rear Case: step 3, image 1 of 1
      • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
      Ask FixBot
    2. Samsung Mythic SGH-a897 LCD Replacement: step 4, image 1 of 1
      • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
      • Working along the seam, pry the back casing from the phone.
      Ask FixBot
    1. Samsung Mythic SGH-a897 LCD Replacement, Camera: step 5, image 1 of 2 Samsung Mythic SGH-a897 LCD Replacement, Camera: step 5, image 2 of 2
      • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
      • Carefully remove the camera from the phone's motherboard.
      Ask FixBot
    1. Samsung Mythic SGH-a897 LCD Replacement, Motherboard: step 6, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the two 3.8mm screws.
      Ask FixBot
    2. Samsung Mythic SGH-a897 LCD Replacement: step 7, image 1 of 2 Samsung Mythic SGH-a897 LCD Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, firmly grip the black lever at the bottom of the motherboard.
      • Use the tweezers to flip the black lever up so that it is upright from the motherboard.
      Ask FixBot
    3. Samsung Mythic SGH-a897 LCD Replacement: step 8, image 1 of 1
      • Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
      Ask FixBot
    4. Samsung Mythic SGH-a897 LCD Replacement: step 9, image 1 of 2 Samsung Mythic SGH-a897 LCD Replacement: step 9, image 2 of 2
      • On the right from the lever, use the tweezers to unclip the black connector.
      Ask FixBot
    5. Samsung Mythic SGH-a897 LCD Replacement: step 10, image 1 of 2 Samsung Mythic SGH-a897 LCD Replacement: step 10, image 2 of 2
      • Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
      Ask FixBot
    6. Samsung Mythic SGH-a897 LCD Replacement: step 11, image 1 of 1
      • Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
      • Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
      Ask FixBot
    7. Samsung Mythic SGH-a897 LCD Replacement: step 12, image 1 of 2 Samsung Mythic SGH-a897 LCD Replacement: step 12, image 2 of 2
      • Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
      • Carefully lift the capacitor away from the phone.
      Ask FixBot
    8. Samsung Mythic SGH-a897 LCD Replacement: step 13, image 1 of 2 Samsung Mythic SGH-a897 LCD Replacement: step 13, image 2 of 2
      • DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
      • Carefully tilt the motherboard up from the back of the phone.
      • Use tweezers to unclip the black connector.
      Ask FixBot
    1. Samsung Mythic SGH-a897 LCD Replacement, LCD: step 14, image 1 of 2 Samsung Mythic SGH-a897 LCD Replacement, LCD: step 14, image 2 of 2
      • Hold the phone by the black plastic at the ends and gently bend them down so that the middle of the phone is the highest point. Apply pressure slowly until the grey portion pops off.
      Ask FixBot
    2. Samsung Mythic SGH-a897 LCD Replacement: step 15, image 1 of 3 Samsung Mythic SGH-a897 LCD Replacement: step 15, image 2 of 3 Samsung Mythic SGH-a897 LCD Replacement: step 15, image 3 of 3
      Buy
      • Insert the tweezers into the hole to wedge them between the LCD and grey plastic.
      • Once under the LCD, slide the tweezers around the three silver edges until the entire display lifts from the grey plastic.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
Morgan Yost
46 Reputation
6 Guides authored
Cal Poly, Team 17-1, Regan Spring 2013 Member of Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 29
All Time: 2,714
